IDX-PRO+VDI
  • I've also made ​​a small modification in the sensitivity by changing the potentiometer value of 100k for a 10k, annulling the R26 and the positive track potentiometer sensitivity. In this way the detector is gaining a lot of sensitivity and I've also changed the resistance amplitude intervals R7 by a 33-51 Ohms.
    • The search coils 27cm DD: TX wire from 0.70 to 35 laps - 0.587 mH -1 mF parallel capacitor RX wire from 0.15 to 270 laps - 35.6 mH - 0033 mF parallel capacitor. Rx search coil canceled 1mV.
      • Comment
          That is inductance for Black max 950 concentric coil. IDX works the best with that coil.
          I am asking you how it works outdoor becouse you made a DD coil with same inductance.
          I never tried it.
          • Ok.Is the inductance for Black max 950 concentric coil.
            • IDX
              Please clarify this:
              DD coil
              TX coil .70 MM wire thickness,1 mf capacitor replaces what? C21? or ?
              RX coil .15 MM wire thickness .0033 mF capacitor replaces what?
              Is there a schematic that represents your PCB?
              thank you
              • The capacitors must be put inside the search coil.
                • I WAS WRONG, but it CAN be done uing the X into the Vref method, then there is no need for complex maths. BUT.. I applaud your BRILLIANT solution Holyuser. I have been intending to do the same thing for a LONG time, but never found the time (or inclination).
                  WELL Done, now about that ACHTUNG MINEN removal.. I would like to license the software off you with a message of MY choice inserted. Please PM me to dicuss payment etc if you are interested.
                  • IDX
                    Holyuser, on the VDI board, what is the value of R2? I am using a 12-13v supply.In other words is PIC pin #2 supposed to read a certain V value? thanks
                    • You must calculate the value of the resistor so that a fully charged battery at the entrance of the processor (pin 2) is 3.1738 volts, if VDD is exactly 5.000 volts
                      • Originally posted by Sean_Goddard View Post
                        Do you like this? http://www.youtube.com/watch?v=xtTIY6zK35c
                        • Hi, Random, you are the master
                          :clap
                          • Originally posted by holyuser View Post
                            If you don't mind sharing ... how did you get that nice battery indicator symbol on the LCD display?
                            • Qiaozhi,
                              It's called a custom charactor. Here is one description.
                              Latest news coverage, email, free stock quotes, live scores and video are just the beginning. Discover more every day at Yahoo!
                                I do not mind sharing.
                                Using PIC-BASIC looks like this:
                                DATA 'Define User Characters into EEPROM
                                4,4,4,31,4,4,4,4,_ ' CGRAM 0
                                0,0,12,0,12,0,0,0,_ ' CGRAM 1
                                14,31,17,17,17,17,17,31,_ ' CGRAM 2
                                14,31,17,17,17,17,31,31,_ ' CGRAM 3
                                14,31,17,17,17,31,31,31,_ ' CGRAM 4
                                14,31,17,17,31,31,31,31,_ ' CGRAM 5
                                14,31,17,31,31,31,31,31,_ ' CGRAM 6
                                14,31,31,31,31,31,31,31,_ ' CGRAM 7
                                FOR i = 0 to 63 'Loading User Characters into CGRAM
                                READ i,char
                                LCDOUT char
                                NEXT i
                                P.S. The first two symbols are not for battery.
