Originally posted by bernte_one
IDX-PRO+VDI
Originally posted by holyuser View PostYou must calculate the value of the resistor so that a fully charged battery at the entrance of the processor (pin 2) is 3.1738 volts, if VDD is exactly 5.000 volts
Apologies for a dumb question
If I put kits together what range of resistors should I supply for R2 ?
Hi Holyuser,
What do you think about using one or several ports RA5/RA6/RA7 of the VDI µP to drive an audio stage ?
In exemple :
- below 0; all outputs set to zero.
- between 0 and 10 : RA5 set to 1
- between 11 and 30 : RA5 and RA6 set to 1
- etc ...
With a BCD decoder, you can even have up to 8 command lines ... meaning 8 differents tones !
It will be fine if the user can choose the number of thresholds and the values of them.
But it's just an idea ...
Hi Hugo,Originally posted by hugo View PostHi Holyuser,
In exemple :
- etc ...
- RA5 is input only, not possible to be used as output;
- RA6 and RA7 are reserved for external crystal resonator;
- RB0 is left free to be used for sound or TX drive, but that will be possible if PIC runs at 16 or 20 MHz.
@Holyuser :
Ok, I understand.
So, I will say it differently ... Can we imagine a special version of the VDI, closed to the original schematic (without an external oscillator), able to pilot the audio ?
What do you have into your brain ?I mean, that RA6 & RA7 are reserved in my project, not generally.
Value of R2 depends of battery type, Vdd and R1 precision.Originally posted by silverdog View PostApologies for a dumb question
You can calculate it using the equation:
, where:
Vbat - is voltage of the fresh battery used (in Volts);
Vdd - is microcontroller voltage supply (in Volts);
R1 - in kOhms
In example, if You fresh battery is 12,6V and Vdd is exactly 5,0V and R1 = 20 kOm, then Your R2 must be:
You can use in this case 6,8 kOhm resistor, I think...
Apologies, more dumb questions
I guess if your R2 value is incorrect the only consequence is inaccurate battery display ?
Could you explain the formula in steps I can't see how you get 6.7K from those values
On the Schematic there is no value for C1
Yeah, right!Originally posted by silverdog View PostI guess if your R2 value is incorrect the only consequence is inaccurate battery display ?
In the present example, would be like that:Could you explain the formula in steps I can't see how you get 6.7K from those values
1. we must firstly calculate 1024x12,6=12902,4 and 650x5=3250 ;
2. in the next step we find 12902,4/3250=3,97 (approximately) ;
3. next, we can find denominator as 3,97-1=2,97
4. finaly we divide 20 by 2,97 and voila! 20/2,97=6,734 (approximately)
This question is not to me, because that C1 is not part of VDI, but...On the Schematic there is no value for C1
I think, that something about 1nF would be good.
In my opinion, this capacitor is used to reduce the influence of cable.
Hi to all
This link is my new vlf project. I used atmega8 microcontroller.
For only video:
I will share all documets of this project very soon too.
