i don´t no....but read this!
IDX-PRO+VDI
My idx depth homemade 10" DD
There are lots of air test results availble for kits but few in european soil - taking inspiration from dons ground tests I set up a bed. 1" depth increments, short lawn on top.
Targets are 0.5" diameter lead balls.
Disc open 7"
Disc rejecting nails etc 5"
I will arrange an AIR and add.
S
WOWW!! compliments! , atrleast i know blue deep is working ,but mine not yet
i hear beep only if i move very fast some metal in the center of coil.
only turning GEB make some difference ,other pots if iturn left or right nothing change.
Originally posted by Schatztaucher View Post
hi at all,
I want to build my second idx. This time the board with 2 ton.
I have some questions for the experts. what to consider? must be changed something at the idx board?
and a second question: the sensitivity of the vdi is not very high. about 15 cm for an euro. is there a possibility to improve the sensitivity? which are the best for the vdi connections, on the idx board?
i hope somebody has some answers....
best regards, marc
Hi, best way to add 2tones to idx is connect it by a switch like in scheme in #1320 at colector of Q3 in this way You don`t have to change anything. 2 tones indicates all metals rejected by discrimination soe use it all time is torture for your ears. I switch from 1tone to 2tone when I found a target, it is very helpfull to identify rusty iron
. About sensitivity of vdi it is hard to improve it, i trayed some things but with no result
Regards.
