Originally posted by kaligula
IDX-PRO+VDI
You have something wrong mpsa 13 should remain cold even with the 8 ohm speaker
Most likely a solder bridge or short. Possible an incorrect component placement
check the voltage pin 1 and 7 of U5 should be just under 3V
Without pictures we are in the dark
With earphones mpsa13 is cold, speaker from laptop 8ohms 1 wats is making problems or is getting burned. You need to try with bigger impedance speaker. But my problem is different. When I turn it on I have sound nonstop at 300 hz square with or without coil. Sound goes off only when I remove Ic7. When I remove all iCs and only Ic7 stays I still have that sound. PLEASE FOR HELP. can anybody post picture here from the last pcb without potentiometer to look for short contact.
Not a 100% sure I tested with 8 ohms but tried a few speakers that I had lying around pretty sure a 8 ohm will have been in at some time. Original I believe is a 32 ohm.
Be careful if you are using a metal case as the audio uses the - volts and not ground
Now I was looking for problem on my Idx and I found one mistake. At the place of the resistor of 100k. next to pp connector I connected pinpoint with what i provided 8v on pin 12 of 4066. So it still have same symptoms after recovering this mistake, but I have to replace 4066. There are big chances to be burned.
Now i have sound, coil is working (i didn't yet maked idx coil, im using coil from tgsl), but i have pulse signals like when we move something over the coil or like digging target, now mpsa 13 is cold, but U4 going hot after 5 seconds. I have replaced U4 and 4066, no changes, stil the same. Here is my pcb. Does this diode near U3 need to be reversed? Im using this lay file.
