BARACUDA-Legend-1
  • Originally posted by ApBerg View Post
    Hello Mohandes,
    . [ATTACH]24580[/ATTACH][ATTACH]24581[/ATTACH]
    think this are the JPG's that are for the baracuda as in the forum, the pcb is copper outsides 94 mm (..I made to many different layouts) so check things before you start ! The circuit diagrams are at the start from this baracuda topic, made by Alex . Before you start look at them to see what parts you have in Iran or what replacement you can get and collect the needed data sheets from WWW to see the pin-connections.
    Succes
    thanks man ok i will Attention to equivalents pins.length is 9.4cm but what size of Width?
    thanks
    • hello mohanes
      easy print the layout and see at printout if ic socket or ic fit onto holes
      also check caps most 5mm spacing
      if printout is not right sizes scale printout via printer control
      • thanks my friendd bernte
        • long pcb
          I redid the PCB. The long version. I do not do it. Check before assembly.
          • thanks
            but the sprint layout can not open
            • Thanks smity nice board, should be easy to etch as well!.
              Did you miss-spell barracuda on purpose? if you did nice joke.
              • Somebody posted a photo of an Anchor Baracuda PI detector, with Baracuda clearly spelled thusly. Strange, because I have seen a picture of the cover of an owners manual that clearly spells out "Barracuda". You can take your pick.
                Maybe the Baracuda was a forgery... or maybe it was a labeling error.
                • Originally posted by mohandes View Post
                  thanks
                  The file type "lay6." Open the program sprint layout 6.
                  • ok
                    but i think error in my computer again not open
                      It seems that the error in the "label"... everywhere says Barracuda, only on the label of a box detectors, writes Baracuda (any I have ever seen on the internet)...
                      Does the English pronunciation pronounced "two R" - BaRRacuda?
                      • Originally posted by maikl View Post
                        Most places in US pronounce the first syllable of barracuda like "BEAR" as in "grizzly bear".
                        People from the deep south (Alabama, Mississippi, etc.) they might say "BAR" as in, " Let's go git sum dranks at the bar".
                        Or they might say "'cuda", or maybe say "bar'cuda".
                        It is way too late for me to have written anything. Seriously.
                        • Had the Jim Pugh (Anchor Electronics Barracuda) was a Serb such errors would not be... because the spelling rule is "write as you speak and read as it is written" and "one letter one sound"...means it would be easy "Barakuda".
                          Best regards.
                          • Hello to all, can someone provide me the scheme in electronic format EAGUE program?
                            Thank you.: Thumb:
                            • Fixed a bug in the printed circuit board (post number 694). There has been no power to the 8 pin 7660. Corrected circuit board in the archive.
                              • hello smity many thnaks for a longboard
                                would you please post a black white picture jpg or gif format
                                is it sprintlayout 6 format? because of ending ***.lay6 ?
                                kind regards
