Originally posted by Geo
View Post
yes there are the 2diodes for op amp supply...like in xr-71 and it cannot work at 6 volts with original op amps I think...but using e.g. tlc2262 it could cause these devices require less supply voltage instead of tl0x2 types.
Also other things could do the job I think, like:
TLC2252
TS272
TS27M2
TS27L2
MC33178
LS204
Anyway I've never tested...just my hypotesys. For other components it's not a problem having less supply voltage (cmos, 555 etc).
Instability is due to nearing of saturating voltages with useful signal...then when signal increase we can easy have saturation on op amps.
With rail-to-rail (e.g. 2262) problem is well reduced and you haven't any istability. Also consumption is much lower...than with TL0x2 series.
Best regards,
