Wow it worked KT I can't believe how well it works I am testing with a 30 cm coil I am getting well over 35cm on a brass token. I will test tomorrow with more stuff and a ruler to get real distances. Thanks for all the support.... but I bet I still will have more to ask from the "hero of Lithuanian".
Delta Pulse
best words I have ever heard Calebsone =) thank you for the nice feedback. waiting your detailed report...Originally posted by calebsone View PostWow it worked KT I can't believe how well it works I am testing with a 30 cm coil I am getting well over 35cm on a brass token. I will test tomorrow with more stuff and a ruler to get real distances. Thanks for all the support.... but I bet I still will have more to ask from the "hero of Lithuanian".
This is the rest of archive from thunting.com
Delta_Snifferxr71_single_side_pcb-_ready_to_build_FINAL_11-22-09.zip
turkish design is one sided and is very huge board be cause. bulgarian I took for a base and did new refreshed. I did put all resistors at board and addOriginally posted by sdesic View PostIs this Turkish design or Bulgarian ?
all pots. so the new board now seems more comfortable IMO. I do not make PCBs in sprint layout, files in P-CAD 2006 are at DVD-ROM included I send free with the board.
This one that was sent by Silver Dollar and me is Turkish - 180x90 mm
www.teknolojiekibi.com one sided design
But is it working?
I don't see part placement for diode ST TH1210D ...
KT I just thought of this I am almost done with my enclosure and set up but do you think shielding the coil is a good idea I mean my hand doesn't set it off.also will that make me lose depth because I thought the large coils are unshielded.BTW this is a small 30cm so I don't remember if this was adressed I get it the box needs to be but just not sure on the small coil.
Calebsone, I do not see so sharp hard necessity to make shielding the coil - be cause the coil is mono, one end of winding 'cold end' is connected to +E (the point of the shielding), another end 'hot end' connected to MOS-FET's DRAIN pin. also in plus, resistance of the coil is very small - 1-4 Ohm, that gives good electrostatic Faradey field protection of hot end too.
... but if you so want to make the graphite aerosol shielding so do... on your choice...
above I have wrote about a shielding of housing... that is STRONGLY NECESSARY to make for DP.
