Delta Pulse
Hi to All,
I'm new member and this is my first post, I built Delta Pulse 2 (Turkish one sided PCB) with coil 19 cm, enameled copper wire 0.4 mm (I just have one role of it) with 31 turn. So, my questions are:
1- How can I make my DP 2 metal detector sensitive to IRON with small pieces ?
2- What is the best frequency to detect iron with small targets ?
3- What parts of the PCB must be changed to be able for iron detecting even small pieces ?
4- any advice for coil ? and what is the best dimensions of coil ?
I'm looking for you answers and advices,
Hello! I made Delta Pulse detector(I used KT315 designed board), made test coil(12 cm diameter and 36 turns of 0.4 mm wire). I got constant sound from speaker, but no reply to metal objects, when i connect oscilloscope to the testpoint T1 in schematic(output of the preamp), I can see there reaction to metal objects. I also checked T3, T4 and T5 with oscilloscope, these were ok. What should I get at T6 and T7 and what should I check?
Following a complaint from another Geotech member, I have to remind you:Originally posted by aojieage View Post
The Tech Forum is for general tech discussions on all types of metal detectors: VLF, PI, 2-box, BFO, off-resonance, PLL, etc. Questions, ideas, and anything else that moves you. ..... BUT, not advertising.
Please us the Free Advertising section.
aojieage was not promoting Delta Pulse. He was advertising the Chinese website TaoBao.Originally posted by kt315 View PostDelta Pulse does not needed in additional advertising. Delta Pulse is the perfect working deeper impulse detector released and checked in
thousands copies worldwide.
George, those chineses crap overloaded my email box by bare spam requests to give them 'deeper detector on gold on 3 meters depth'.
so let me overload those bad guys by something they are served up too. they always only ask but never give useful info in the exchange.
i got 1-3 messages everyday!
yours
It is best to ignore all such requestsOriginally posted by kt315 View PostGeorge, those chineses crap overloaded my email box by bare spam requests to give them 'deeper detector on gold on 3 meters depth'.
yours
or tell them to post their questions in the forum. Otherwise the questions will be endless.
PNow the detector is working, there was just a stupid mistake- one IC wasn't installed properly.Originally posted by Davis9000 View PostHello! I made Delta Pulse detector(I used KT315 designed board), made test coil(12 cm diameter and 36 turns of 0.4 mm wire). I got constant sound from speaker, but no reply to metal objects, when i connect oscilloscope to the testpoint T1 in schematic(output of the preamp), I can see there reaction to metal objects. I also checked T3, T4 and T5 with oscilloscope, these were ok. What should I get at T6 and T7 and what should I check?
