Induction Balance Stuff - Single/Multi Frequency Response, GB, Disc, Measurements, Ideas, Fun, etc.
  • The gofind uses an impedance bridge strategy as a means of reducing noise and simplifying coil topology over balanced DD or OOO coils. .... it was hardly your state of the art detector when marketed though being sold in the sub $200 bracket.
    Below is detail from the coil connection .... theres a cap across one of the coils ...RX maybe or is it in series ? ...
    The patent talks about impedance change and noise reduction but not really ground reduction / X cancellation.
    Click image for larger version  Name:	image.png Views:	0 Size:	322.0 KB ID:	444911
    • I'm just suggesting the approach as a way to make an equivalent VLF detector with a mono coil. It otherwise has the same responses as an IB coil. The Go-Find version resonates the search coil and replaces the balancing coil with a resistor-equivalence by using matched anti-phase resonated coils, all stuffed into the coil housing.
      • Hi all,
        thank you for the interesting suggestions.
        I'll think of the ideas.
        The design priority has been changed to software coding for a while. I have to clean up all my metal detecting software code first. There is a lot of experimental code mostly implemented in quick & dirty style, must go now. (I know, I shouldn't do this as a software engineer. )
        A clean and lightweight version is the goal. So I can start different projects, which does not inhere with the other coding stuff. This is overdue.
        Cheers,
        • Hi Carl,
          this is for sure a good KISS project destined for my software sanity project.
          Proposal a)
          This is like an LCR-measurement setup (Impedance measurement).
          Proposal b)
          This is more interesting as I can push more current to the TX coil. I like it.
          Coil1 and Coil2 should be realised as a variable inductance (screwable ferrite core inductor housing for both coils to match the search coil impedance).
          We can tap a TX reference signal on one side of the feed to make synchronous detection possible. Then the impedance change can be measured.
          I will try both versions to see the SNR and sensitivity. I like it due to mono coil design.
          • Hi all,
            the proposal a) is by far enough. Instead of balancing, the balance resistor is used to limit the coil current. I don't need the balancing as the signal won't be amplified further or to behave like an IB RX-Coil.
            The sensitivity is not bad for the simple mono coil design. But the coil needs absolutely good shielding. The phase shift is more stable (1/1000 degree stable) and sensitive than the amplitude change (slightly more noise).
            • Hi all,
              unfortunately, the software sanity project is progressing very slowly. But I'm using AI generated code portions now.
              This is really fck'n nice and efficient.
              I have found a lot of "under construction" and todo parts in my code. Even features, which haven't been implemented yet. And I am bug fixing too (according to the todo list).
              I will very likely leave the old code section parts and add clean and lightweight new modules. This is the fastest way at the moment.
              Cheers
              • Hi all,
                now look at this fine AI code for Hilbert transform (Allpass FIR Filter type III for quadrature signal generation). The AI has generated and optimized the code after doing an AI query.
                I have added assertion-codes, my own memory allocation function wrappers to detect memory leaks in the system and floating point typecast REAL. And I have optimized little things only.
                Code:
                #ifndef PI
                #define PI 3.14159265358979323846264338327950288419716939937510
                #endif
                typedef struct
                  int   N;           // Gesamtlänge (N), muss ungerade sein
                  int   pos;         // Aktuelle Schreibposition
                  int   nC;          // Anzahl der gespeicherten Koeffizienten
                  REAL  *buffer;     // Double-Buffer für modulo-freie Faltung
                  REAL  *coeffs;     // Nur ungerade, positive Koeffizienten
                } HilbertFilter;
                HilbertFilter* hilbert_init(int N, BOOL bHamming)
                  HilbertFilter *hf;
                  int i, M, n;
                  REAL hamming=1.0;
                  if (N % 2 == 0)
                    N++; // Sicherstellen, dass N ungerade ist
                  hf = MALLOC(sizeof(HilbertFilter));
                  ASSERT(hf);
                  hf->N = N;
                  hf->nC = (N - 1) / 4 + ((N - 1) / 2 % 2 != 0 ? 1 : 0); // Nur ungerade Indices
                  hf->coeffs = MALLOC(hf->nC * sizeof(REAL));
                  ASSERT(hf->coeffs);
                  hf->buffer = CALLOC(2 * N, sizeof(REAL));
                  ASSERT(hf->buffer);
                  hf->pos = 0;
                  M = N / 2;
                  n = 0;
                  for (i = 1; i <= M; i += 2)
                    // Hamming-Fenster (optional)
                    if (bHamming)
                      hamming = 0.54 + 0.46 * cos((2.0 * PI * i) / (N - 1));
                    // Idealer Hilbert-Kern * Hamming-Fenster
                    hf->coeffs[n++] = (2.0 / (PI * i)) * hamming;
                  } // for i
                  hf->nC = n;
                  return hf;
                REAL hilbert_process(HilbertFilter *hf, REAL input, REAL *quadrature)
                  int i, n, N, M;
                  REAL q, inphase, *window;
                  ASSERT(hf);
                  ASSERT(quadrature);
                  N = hf->N;
                  M = N / 2;
                  // Lese-Basis für das älteste Fenster
                  window = &hf->buffer[hf->pos];
                  // Double Buffering: Sample an zwei Positionen schreiben
                  window[0] = input;
                  window[N] = input;
                  q = 0.0;
                  // Symmetrie-Optimierung: Nur ungerade n nutzen
                  for (i = 0; i < hf->nC; i++)
                    n = 2 * i + 1;
                    // h(n) = -h(-n). Wir nutzen (x[M-n] - x[M+n]) * h(n)
                    q += hf->coeffs[i] * (window[M + n] - window[M - n]);
                  } // for i
                  *quadrature = q;
                  inphase     = window[(N - 1) / 2]; // Delayed center sample
                  hf->pos = (hf->pos + 1) % N; // Modulo nur für den Pointer, nicht pro Multiplikation
                  return inphase;
                ​void hilbert_free(HilbertFilter *hf)
                  ASSERT(hf);
                  ASSERT(hf->buffer);
                  ASSERT(hf->coeffs);
                  FREE(hf->buffer);
                  FREE(hf->coeffs);
                  FREE(hf);
                This part of the nice and fast code will be used in my project now. It replaces the slow FFT function for demodulating external signals (RX) with external reference sources (TXRef). Just like demodulating free running LC oscillator signals, where you don't know it's frequency usually. And the frequency isn't fixed (drift, change, etc).
                I had a good lecture lesson in AI prompting now.
                • Hi all,
                  here is a good explanation of the Hilbert-Transformation and its applications. Easy to read and understand.
                  Link: https://medium.com/@RaghavKrishna25/...s-206edb017f2f
                  The algorithm above is very useful to form a high-pass filter too. Just reduce the tap-size (filter size). So the low frequency EMI noise will be attenuated. And it also reduces spectral leakage effects due to inherent in-built Hamming windowing. The windowing doesn't cost extra CPU power, because the Hilbert coefficients are modified with the windowing coefficients.
                  Note, that the Hilbert filter has some delay for both I (In-phase) and Q (Quadrature-phase) channels. Use the returned I and Q values from the hilbert_process() function. The function enables sample-by-sample real-time processing.
                  Cheers
                  • Hi all,
                    BTW, the Hilbert-Transformation makes decay rate processing easily possible. A tuned PI coil with capacitor (defining a resonant circuit) and optional high damping resistor (additional fixed decay rate) will be ringing and decaying during off-time. It behaves like off-resonance principle. The envelope of the ringing decay can be demodulated easily. The processing can be done on the envelope decay. And we have the true "analytical signal" (it is called so, the quadrature form) of the decay ringing for further infos (frequency estimation, phase lag, etc.).
                    Look at this paper:
                    https://www.bksv.com/media/doc/bo0437.pdf
                    Who has said, that a ringing coil is bad?
                    • Look,
                      the google AI code for phase unwrapping in pure standard C implementation (max optimized).
                      Code:
                      #define TWO_PI 6.28318530717958647693
                      #define INV_TWO_PI 0.15915494309189533577
                      void unwrap1D_max_perf(double* restrict data, int n) {
                          if (n < 2) return;
                          // Lokale Kopien für Register-Caching
                          double last_val = data[0];
                          double cumulative_offset = 0.0;
                          for (int i = 1; i < n; i++) {
                              double current_val = data[i];
                              double diff = current_val - last_val;
                              // Schnellstes portables Rundungsverfahren ohne math.h
                              // Nutzt die implizite Truncation beim Cast
                              double ratio = diff * INV_TWO_PI;
                              int shift = (int)(ratio + (ratio >= 0 ? 0.5 : -0.5));
                              cumulative_offset -= shift * TWO_PI;
                              // Update und Store
                              last_val = current_val;
                              data[i] = current_val + cumulative_offset;
                      Do we need a phase unwrapping tool? YES!
                      The analytic signal (z) of the Hilbert-Transform delivers the phase Phi(t). This is the arg(z). arg(z) = atan(Q(t) / I(t)). t is the time variable.
                      Before we make the first derivation of Phi(t), we need the phase unwrapping.
                      We can calculate then the current frequency f(t) of the signal.
                      f(t) = 1/(2*pi) * d Phi(t)/dt
                      f(t) is the current frequency at time t
                      This is how the frequency can be determined. The unwrapping of the phase is important. This part of the code goes to my library now.
                      The AI has stolen code and knowledge from engineers. And I am stealing the AI code and knowledge back.
                      Cheers,
                      • What's next?
                        Combining a band-pass filter with Hilbert-Transform. Realized and optimized for C code. With Hamming windowing. Double buffering. Avoiding modulo % operator. Optimized for light-speed.
                        AI do this for me please! AI? AI? AI? WTF!
                        Well, next time.
                        • Oh man,
                          the AI says, we modify the Hilbert coefficients for band-pass functionality.
                          Well this can be done as a separate function, which applies the filter to the ideal Hilbert coefficients. This is really minimal.
                          This is the core of hilbert_init(). Variables might differ to my publication above. The principle is shown only.
                          Code:
                                      // 1. Ideale Hilbert-Komponente
                                      double h_ideal = (1.0 - cos(M_PI * k)) / (M_PI * k);
                                      // 2. Bandpass-Komponente (Sinc-Differenz)
                                      double h_bp = 2.0 * (f_max / fs) * sinc(2.0 * f_max * k / fs) -
                                                    2.0 * (f_min / fs) * sinc(2.0 * f_min * k / fs);
                                      // 3. Hamming-Fenster
                                      double window = 0.54 - 0.46 * cos(2.0 * M_PI * n / (N - 1));
                                      coeffs[n] = h_ideal * h_bp * window;
                          We have to include the h_bp factor to the Hilbert coefficients.
                          There we have. Hilbert-Transform + band-pass.
                          I should have asked this AI before. Well, I have to do it by hand now.
                            F! me!
                            The AI even makes the changes for me.
                            • From the Hilbert filter coefficients:
                              a) h_ideal = (1.0 - cos(PI * k)) / (PI * k), from above code
                              vs.
                              b) h_ideal = (2.0 / (PI * k)), from the optimized code
                              What is wrong?
                              Wolframalpha failed to solve this. Google AI made it correct.
                              k is >=1 and odd (1, 3, 5, 7, ..)
                              What happens to the term cos(PI*k) for k=1, 3, 5, ...
                              cos(PI*1)=-1,
                              cos(PI*3)=-1,
                              cos(PI*5)=-1
                              and so on.. = -1
                              The formula a) simplifies to
                              h_ideal = (1 - (-1)) / (PI * k)
                              h_ideal = 2 / (PI*k)
                              which is the formula b).
                              I thought, that the AI made a mistake perhaps. Nope! It's fully correct. If you don't ask for optimization, you get more complex and inefficient formulas or solutions.
                              Next time, I will ask the AI the optimized question with infinity entropy for the answer 42!
                              • Aziz, here is something you've always dreamed about!
                                https://www.aliexpress.com/item/1005...origin_prod%3A
