TESORO GOLDEN SABRE
  • Hello!
    I've just completed my first TGSL and made some field tests with it and here is some experiences and questions. Performance is so far not very good, 25cm for 1 euro coin and vegetation is giving false beeps. I think I borked the shielding when trying to "slot" it to reduce eddy currents and to get a better null. So I got noticeably lower rx voltage but most of the slots ended up as several millimeter holes in the aluminum tape.
    Next coils are going to have probably low conductivity shielding but can't find much information on this. Can you give any advice on this? Does graphite paint work or maybe some conductive plastic like carbon tape? I also tested coloring a piece of painters tape with ordinary pencil, it seems to make a thin and promisingly cheap alternative.
    I also found that I can possibly identify difficult trash objects like rusty bottlecaps or rolled foil if I vary swiping speed. These trashes seem to make a shorter beep if search head is swiped faster and disappear completely if swiped even faster. Disc was set to reject thin foil pieces. I would like you to confirm this.
    • thank you guys, but i found on ebay http://cgi.ebay.com/3000-30-AWG-Copp...item53d74c0afe
      it is the simplest to pay, and i have enough wire for 6 detectors
      I just want you to confirm me that this wire is good for this metal detector !!
      Thx in advance !!!
      • A few wild guesses here from someone who has made several VLF detectors, but older designs like the ETI549 for example. But I can help I feel.
        Provided that you know the coil size(s), the number of turns and the wire thickness, and you follow that exactly, you should end up with two good coils.
        I then wrap the coil tightly with insulating tape for its complete length to stabilise it.
        Then I wrap the coil with a meter or so of bared, multi-strand tinned copper wire, making sure that the ends do not touch, with one end I leave a yard or so (meter or so) of the wire with the insulation still on it, though I probably don't need that much, this part comes away from the coil near to the exit points of the coil connections, usually between them.
        This is the contact for the Faraday shield that I now start to make.
        What I have used in the past is to take a meter of silver cooking foil and cut it into strips. Hold the start tightly with more insulating tape and wrap the strips around the coil, leaving an open end where the contact wire ends, at least a 10mm gap. A short across the Faraday shield is difficult to detect (joke) and correct, so be very careful.
        Then using more insulating tape, tape the whole coil carefully, including the 10mm gap.
        Make sure that you can identify the start and finish of the coil as some detectors, I am told, it makes a difference to the sensitivity of the whole machine, if one coil is "reversed" to the other. How true this is I cannot say.......but a swap round of the connections to one coil may improve sensitivity in some cases....just be aware.
        There are several styles of coil placement, the overlapping double "D" is good as it has a wider search path, especially for items that are not so deep, but some prefer what is called the co-planar which is basically a small middle coil and a far larger coil following the surround of the head, that a loop is passed to be "inside" the small coil, so that pickup is nulled in the absence of metal.
        The co-planar I have never used personally, though I have one in the making somewhere in the cellar!, always the double "D".
        For a double "D", he two coils need to be laid in such a way that again the pickup on the Rx coil is nulled. In fact, I always used my wedding ring to check and I went slightly out of the null on simple machines, that was found to be the "Gold" side, simply so that if non ferrous metal was detected, the signal rose immediately, but if ferrous metals were detected, it went "back" through the null first, giving an quiet interlude before coming out of the null and producing a signal. Discrimination without the control complexity!!!
        The coils need to be carefully glued down (in the well known shape)using epoxy or similar, adjusting all the time, till the epoxy is hard and the coils unable to move any further.
        I used an old cotton shirt, cut into strips, filled with epoxy and wrapped round each coil as some glues do not stick to plastic tape, allowing movement, which can cause instability. Its a messy business, use rubber gloves and clean off any epoxy with methylated or de-natured alcohol, which works fine till the glue is dry!
        I do believe that the method applies to many VLF DIY Projects....
        I admit that although I am planning to build one of these detectors, I still have a lot to read here first and I hope that my tips are actually applicable to this design..... My full apologies to all if that is not the case.
        Andy
        PS. If anyone needs more details, especially about the shapes and placing of the coils, I could make or copy a few simple pictures if needed, just ask!
        • Originally posted by juka vk View Post
          Thx in advance !!!
          Sho 'nuf.
          • Hi,
            I downloaded a copy of your well thought out manual yesterday, a rather long time after your request for suggestions, so are you still interested in any new ideas? or are you happy with the result (I flicked through and thought it was really good, even pioneering in many respects).
            By the way I have no suggestions at this time as I did not yet study it in depth (it is probably still in good order even then!!), but just in case......
            I would imagine that I am one of many, many people simply delighted by the quality and the thought you put into this extensive document.
            I am going to buy one of Silverdog's kits in the near future and your "Manual" was a gift from heaven....
            Andy
            • Eastern & Western Treasure Magazine.
              Well they published one of my articles for the August 2011 edition! If anyone in the U.S. subscribes it's one of the smaller articles near the back. So what's this have to do with the TGSL thread? Almost all my finds over the last 2 years were made with Ivconic's TGSL version.
              Don
              • A couple of pictures says it all. Congratulations on getting the article published Don! You have that talent of expressing things very well in writing.
                Jerry
                  Don
                  Inspiring!
                  • With regard to tying off with and without resistors, did you check and see if there was a difference with regard to current used from the metal detector?
                    I see no reason to save on a few high quality resistors that I can buy for about $3 per 100, unless there is a positive gain with regard to current drawn from the battery.
                    Thanks in advance
                    Andy
                    • WHAT resistors? What are you talking about? Think or buy ready-made detector
                        Thanks in advance
                        Andy
                        Are you are referring to the unused LM358 op amp?
                        I have not checked the current with a test... but good idea! Let's do it.
                        • oh... but its better to make it V-folower with input grounded. Not just removing resistors
                          • Originally posted by habitbraker View Post
                            Yes, don't just remove resistors! See: http://www.geotech1.com/forums/showp...postcount=4682 for dual supply with no resistors.
                            Always a good idea to test the current as well to make sure.
                            • OP Amp Resistors
                              Thanks to you and Habitbraker for answering my query so well, I don't have the possibility to check myself at this time.....
                              Andy
                                Hello, i have poblem with buying copper wire. Can you please tell me where can i buy wire online. I prefere ebay but i can't find copper wire there!!!
                                please help !!!
                                here you can buy but ask for shipping to your country
                                http://www.spulen.com/shop/index.php?cPath=72_27
                                i bought last week a 1kg 0,25 spool ( 2200 meters) for 22 euro or so
                                http://www.spulen.com/shop/product_i...oducts_id=1423
                                better is this you can heat it and it melts togehter
                                http://www.spulen.com/shop/product_i...oducts_id=1434
                                read here for this type of wire by translator
                                http://www.elektrisola.com/de/backlackdraht.html
