TESORO GOLDEN SABRE
  • There out there. I tried one here on a Garrett detector because of a local Radar and it helped.
      I haven't tried it yet, but trying to think how it might work. I'm guessing it chokes off any "common-mode" signal coming up the cable -- of course we don't want it to block the 14.5 kHz differential signal. Maybe it will be more important with the "grounded RX" coil configuration than the "ungrounded" RX coil configuration, because the ungrounded configuration has better common mode rejection???
      One question I have is how a shielded cable responds to such a choke, and if that is different to a side-by-side pair such as a power cord. I think they work the same, but just wondering.
      I still suspect that the worst noise is picked up by the RX coil and looks like the normal differential target signal, so the choke wouldn't stop it. The only way I can think to reduce it (so far) is dual RX coils which cancel the noise but don't fully cancel the target signal. But it makes a very awkward search head. I've started experiments on that.
      Good points Simon just come out of my workshop and have spent the last 4 hours plus playing about with these emi filters and there is very small amount of difference if any in the workshop conditions but of course we dont metal detect in the workshop do we.
      The best advise I can give is what I said in the past go buy some of that USB3 cable the cable is labled nasa shuttle cable 80 degrees 30v, it has 6 cores incl violet for those who want to stick to Tesro colour codeing, two of the pairs have there own screening then on top of that second mylar independent screening insulated independent of the main heavy screening plus a second over all screening of mylar around the body plus its reinforced with two lots of rope running through the entire lenth, so its also very robust.
      I use the two pairs that have there own screening for TX and RX then solder all screens together both front and back end wired as per Tesro
      And can honestly say I dont get any instabilty problems at all in real use unless ive done a error with the coil nulling, im now down to 6.3mh for RX using .39 gauge and 6.91mh for TX using .25 gauge and im getting my 30cm for £1 coin air test with a nice clean signal in the workshop and 28cm in the test bed which is full of old iron nails etc.
      I cant get any where near those setting with the cheap usb2 cable and once you compare the construction you can see why, Ive proved this no end by swapping cables.
      Firstly we all know and you yourself have proved that spikes been picked up from the TX bleeds through the RX,so what does that tell us... isolate the two best as we can.
      You will always get noise pick up from the search heads and if you try and filter that out you will filter out are finds.
      the cable is the answer and what im using is better results than the cable supplied with the factory coil, infact im thinking of changing the cable on the 8" coil i but dont know the best way round it.
      If you have trouble obtaining the cable give me a shout and next time im doing my orders will by a few 5m lenths and send one over to you, I just hope the price is the same as last time.
      Hope this helps
      All the best
      Dave
        Hope this helps
        All the best
        Dave
        Good cable info, thanks.
        If it turns out that the RX coil picks up the dominent noise, then the cable may be secondary anyway. However, if you can demonstrate that a certain cable really makes a difference over another one, certainly worth investigating. Of course, there can be a number of reasons the cable has an effect.
        -SSB
        • Hi Satdave I mentioned this, but I have not tried,
          There may be some improvement having the cap in the coil head.
          The cable is just carrying signal voltages then , and not oscillating currents from coil to remotely located cap via the cable.
          Steve
            Steve
            Very interesting concept, but am certainly no expert in this area, but as the cap is basically a "tuning" cap, how could that be true that having it in the head stops some signals? The Rx circuit is still carrying an AC receive signal to the electronics, it has been "tuned" thats all.......
            I must admit that I have NOT actually 'scoped such a circuit myself in this area to see what differences there are before and after the cap, maybe next year if you cannot help me more.
            Can you point me to any websites that cover this subject in fine detail so that I can learn more about this?
            Can you also elaborate your own thoughts on this subject please?
            My thoughts that the combination of L & C will give a frequency at which the circuit is most sensitive or "tuned", the length of the cables do two things, they add some more resistance and a small amount of inductance.
            But when the cap is on the PCB, you have a better chance of being able to change or modify it than when its in the search head......
            thanks in advance.
            Andy
            • All I say,
              In order to maintain the least losses - or to keep the maximum efficiency and gain/sensitivity.
              You should strive to minimise loss in a circuit.
              Rx tuned circuits are a little like a pendulum. magnetic energy picked up by the coil generates a voltage across the coil - which charges the cap.
              The energy is passed from L to C and back again using the complimentary electrical properties of Ls and Cs.
              In an ideal world this would be a lossless system.
              The coil and cap should be co located to incur least loss of picked up signal energy for every 'oscillation of picked up signal energy'
              Steve
                All I say,
                Steve
                Dear Golfnut,
                do not be upset but for me that is simply not an electronic answer......it may be basically correct, but I would like to have a proper factual answer please. 100% correct.
                I am certainly not an analog or a radio electronics person, the last time I worked on such circuits they were in a gun turret on an RN warship in the 60's. I am a digital person for many years now.
                I can still understand a correct explanation from someone who works a lot with analog electronics though, perhaps someone else here can help us both further as to what to watch for.....
                Have a great new year and
                Regards from
                Andy
                  All I say,
                  Steve
                  You could try an LTSpice simulation to see if you could demonstrate a significant advantage to locating the cap near the coil.
                  Again I wonder if one advantage of putting the cap on the PCB is to filter out some cable noise.
                  There could be some advantage to putting a high-Q TX coil-cap tank in the search head to minimize the driving current in the cable -- that is, if you ever wanted to play with high-Q TX tanks, which may have some disadvantages such as ground sensitivity.
                  • Hi ALL I am new member of your forum , now i am building tgsl but i didnt find bf 245 i only find bf 240 ...can i use it as substitute for bf 245???
                    thanks
                    bushra_kharif
                    • A BF240 is a NPN Radio Frequency Transistor
                      A BF245 is a N-CHANNEL JUNCTION FIELD EFFECT TRANSISTOR
                      they are not the same type of component
                      • MAX
                        would you still have the picture from your post #564 ?
                        that site has gone now
                        thanks
                        6666
                        • thanks 6666 for your comment on bf 245 and bf240 ,again can i use k118 to substitute bf 245?????
                          thanks
                          • Latest TGSL documents
                            Attached are the latest "TGSL 101" documents. It includes a revision date on the first page along with significant fixes. I also fixed some "bad English".
                            Don
                              Don
                              Thanks for your continuing hard work!
                              At risk of another revision, I'll mention that the revision date in the "part 1" document seems to have year 2011 instead of 2012.
                              Cheers ,
                                Cheers ,
                                Rats.. Sorry about the wasted disk space
                                I've only made that mistake three times this week so far..
