Hi Max and thanks for fast reply.
"** I tested the coils and after i found the nulling point i got 22 cms for a 14 mm coin on air"
good result, but I think you could tune it better...
What about coin , wich metal it is ? Alloy ?
AL COIN
ON A WEDDING GOLD RING, 22 CMS I DIAMETER, I GOT MUCH DEEP (24 CMS)
Some little tricks are related to shield. Have you tested coils without it ?
NO, I HAVEN´T
If so, what's detection range for same coin ?
I LL TRY IT
It's kitchen al roll or something else (I've noticed that aluminium/mylar is better , due to less metal content, but hard to find)?
YES, IT´S KITCHEN AL ROLL
Other issue is the overlapping zone shape and wideness. What about ? Parallel overlapping or oval ? How many millimeters between two windings at center ?
I USED OVAL OVERLAPPING AND SHAPE IT´S THE SAME HAS IVCONIC
FROM CENTER TO CENTER OVERLAPPING IT´S ABOUT 20 TO 30 MM
When you nulled what's the peak-to-peak voltage at RX (dumped)?
I HAVEN´T MEASURE IT, I JUST PLACE THE TWO COILS OVERLAPPING AND TESTED TO THE BEST DEEP I FOUND. ( I FOLLOW IVCONIC METHOD). THIS WAY IS VERY EASY TO DO TO REACH THE BEST POINT.
NOW A FEW QUESTIONS MAX:
1.- IS POSSIBLE TO BUILD THE COIL WITHOUT TIGHTENING TO MUCH, SO I CAN PLAY WITH CORRECT INDUCTANCE. IVCONIC POST THAT 141 TURNS FOR TX AND 151 TURNS FOR RX COIL, FOR A 22 CMS COIL. I USED THE SAME SHAPE AND DIAMETER FOR IT, BUT I HAD DIFERENT NUMBERS OF TURNS TO REACH THE CORRECT INDUCTANCE VALUES. I CONFESS THAT MY COILS ARE TO TIGHTENED. ALSO, CAN I JUST USE A CORD AND THE AL SHIEL TO GET IT WORKING. THIS BECAUSE WHEN I PUT THE ELECTRIC TAPE, MY VALUES GOES OFF FROM THE VALES NEEDED.
2.- MAX, I HAVE TRIED TO FIND A GOOD OWNERS MANUAL FOR THIS GOLDEN SABRE. I STILL CAN GET THE PICTURE FOR THE USE OF REJECT AND NOTCH FUNCTIONS ON GOLDEN SABRE. ALSO, DON´T KNOW WHAT ARE FOR POTS THE TWO POTS ON THE BOARD. I ONLY KNOW THAT ONE OF THEM, HAVE SOME INFLUENCE ON THE KIND AND SHAPE OF METAL DETECTED...ANY COMMENTS ABOUT THIS.
THANKS AGAIN FOR HELP ME AND THE REST OF GOOD PEOPLE HERE.
BEST REGARDS
NELSON
I think that with good tuning you could gain some cms.
Best regards,
Max[/QUOTE]
AL COIN
NO, I HAVEN´T
I LL TRY IT
BEST REGARDS
NELSON
Best regards,
Max[/QUOTE]
. NOW I've seen everything Ivconic, but hey it works!!
