Originally posted by simonbaker
I checked trim, pots, switch connections, it is ok.
On TR4 drain pin (disc channel) i see negative impulses.
And TR5 drain pin (gb channel positive impulses).
According to oscilograms in forum it shoul be on contrary.
So in TGSL_101 documentation i found usb cable connection: J2-1 (U101a pin 5 not inverted) goes to ground in coil head.
In forum i see (also your posts) J2-2, should go to ground in coil head.
Is there a mistake in that manual or in forum?
To check, only connect shields in coil to the cable shield.
I really cant see the big deal and if people on here are doing these projects cant sort that out then they shouldnt be attempting such projects in the first place.
