Originally posted by silverdog
IDX-PRO+VDI
I built one of Silverdogs IDX boards and now would not manufacturer my own IDX PCB. Makes a more reliable MD for use in the field with proper thru plating and varnished tracks. Saves all that drilling. Make debugging much easier if you know the PCB is correct to start with.
This is good to know. You have been out of stock for ages. Any idea of the price in us dollars? I don't do pounds.....
I wish someone would take the 6000di series 3 schematic, and lay out a board for it. And for what it is worth, I'm an embedded systems programmer, with a lot of experience on the 8051 family, some on the pic24, and a lot on a whole batch of other fine processors (68000, 6800,6809,8080,z80,8031,6502, 6811 etc.) No pic 18 though. Consider most of the pics to be junk. Anyone with a 6 bit byte and a 17 bit address is an idiot.
You don't use Arduino ?Originally posted by scrungy_doolittle View PostThis is good to know. You have been out of stock for ages. Any idea of the price in us dollars? I don't do pounds.....
No I don't. I work for a medical device manufacturer and our products are based on 8051's from Sialbs. I've never used the Arduino, but I think the atmel mega is a good processor. I am not impressed with their 8051's because they don't have an embedded jtag debug block like the Silabs processors do. It makes debugging a lot easier. I've been an embedded programmer for over 25 years now.
A second unrelated question, is where does one find the IDX-PRO manual. All I can find on whites site is the classic ID/IDX which has different features from the IDX-PRO
Yes done both polyurethane and epoxy. Well not be using polyurethane again.Originally posted by jlsilicon View PostHas anybody tried mounting a Coil into POLYURETHANE - instead of EPOXY ??
- It seems like a lot Cheaper !!
Works usable but not as good.
Gets quite warm so null shifts.
Not as stable.
Originally posted by golfnut View PostI did a poly one, I wrapped glass strips around my coil - so I didnt have a potted void. So wasnt much curing volume, so didnt get hot.
Large volumes of poly almost smoke during cure and tend to shrink and crack. Small amounts is easier
Are you talking about Polyurethane or Epoxy ?
I did not know that Polyurethane heats up.
The chemical reaction that hardens Polyurethane causes quite a bit of heat. A cup full of Polyurethane would be almost too hot to touch. I found that Polyurethane not a solid as cured epoxy but epoxy does take several days to harden properly.Originally posted by jlsilicon View PostAre you talking about Polyurethane or Epoxy ?
Holyuser, you are obviously sady uninformed. I've reverse engineered everything from microsoft basics, to a russian instrument. A good disassembler, and a debugger, and it will be a no brainer. So I am sure that ivconic will have no problem. Hell, I might even take a shot at it for fun, even though I don't know pic code. The russians said that an object file would do no good for helping reverse the instrument, but they were dead wrong. inside of 2 days I had a fully disassembled and semi commented file, in in 3 weeks I had a fully commented file and understood what they were doing with BOTH micros.
So, an easy way of tightening the coil wires (for full Inductance) is using small twists around the coil - like twisted rope twine.Originally posted by Koala View PostYes not quite as good but the difference is only marginal except for the heat. Both make workable coils.
I have been using this in my past coils making.
- This should not affect the performance - yes ?
