Originally posted by lian
IDX-PRO+VDI
Hello
The device only works in mode pin-point
In your opinion, what is the problem?
thanks to all
Hi Lian, in my opinion, first you have to check the pcb and all connected components are correct, then the wires that go to the potentiometers are too long, finally, you have to make the coil properly, both the tx and rx are tight with a string and the tx is temporarily blocked on a tablet, and the rx is placed on it and the precise point is found to perform a nulling. You have to measure a voltage as low as possible almost close to zero, but even 2 millivolts is the same, this voltage must be measured with an oscilloscope vpp in ac between the ground of the pcb and the sixth pin of the 5534 ic.
Hello, I have some test videos that I shot about idx pro. As an idea
