  • OK. Thank you. a can I use mcp602 instead of LM318 in the schema? and then the characteristics seem to be similar, except for food. I want to use 9v 6f22. that would shove into a smaller body, such as a tube d32-50mm
    • Do you have a smaller PCB that will fit into the tube ?
      The battery is not the critical part here. You can use 3 Li ion 16450 batteries in series. When mounted after each other, they will fit into the tube.
      I normally mount them into the top part of the alu stem of the detector.
      The max power supply for MCP602 seems to be 7V ?
      • Originally posted by F117 View Post
        yes, it also bribes it. so you can not limit yourself to eating with a drop below 10v. as in this case with LM318. power will last for longer, it turns out more economical. or am I wrong?
        • yes, it also bribes it. so you can not limit yourself to eating with a drop below 10v. as in this case with LM318. power will last for longer, it turns out more economical. or am I wrong?
          Sorry, but I don't understand the problem / question.
          Maybe somebody else does ?
          • I mean that:
            MCP602 consumes little, enough for its power 5v, not 10v.
            for LM318 you need 10v. this is not very economical.
            Here and offered an alternative, use it MCP602. I myself can not check, can someone check and report on the work in this performance.
            • for which the data contacts, for which they answer. for what function?Click image for larger version
              • @ POPKA-RU
                They are ICSP contacts for progamming the PIC with PICKIT3/ICD3/or Compatible Universal programmer
                • Originally posted by popka-ru View Post
                  I mean that:
                  Yes you can use MCP602 but you may need to change resistor between output of MCP602 and PIC
                  • Thank you. and then they sent LM318L instead of LM318N. but it really does not work. decided to ask before use as an alternative to MCP602.
                    • I understand that BC549B can be replaced with BC547B, or you can apply 2n7000 to this mosfet.?
                      • and another question, are there any errors in this print?
                        • The LM318 mask is upside down. The traces around it are OK.
                          Pin 8 and 9 of the PIC16F1824 should be shorted.
                            So?
                            • Yes, it looks OK now.
                              Have a look at Arionas' layout in post #200 in this thread/
                              http://www.geotech1.com/forums/showt...764#post223764
                              • Also, the coupling elco on pin 12 for the audio signal is reverse polarized.
                                Looks like you have an old Arionas layout - before he fixed all the initial errors.
