Originally posted by Olly
Inside the .zip file is a sub-directory called 'gerbers', these are the PCB manufacturing files.Originally posted by Boadil View Post
It has the zip with the files for the PCB
Just zip up this 'gerbers' directory and send it to JLC or wherever you plan on having the boards made.
Note that the gerber naming convention is as defined by JLC (They have a guide on their website for producing gerbers from KiCad the way they like it.)
Cheers,
- Likes 1
gurdal
You can find plenty of information on coil / wire sizes in the dedicate coil section of this forum. https://www.geotech1.com/forums/forum/technology/coils
A coil for Pickini v4 is not different from any other generic PI coil.
Inductance: 300 - 400 microHenry --- resistance 1 - 3 Ohm
Here is some info on my hands-on coil build:
According to this post by MartyJ1963 -- a basket coil would give best results.
I never tried it myself:
https://www.geotech1.com/forums/foru...544#post259544
- Likes 1
Can you help me please as I am in new territory. I have the V4.2 source file and hex file here at PICKINI PI Detector but they both appear to be text files. How do I get them from the web site and convert them into something my Picket3 can use? Alternatively, if anyone already has these files in a useable format, would you mind sharing?
MartinB
The file format is Intel Hex. This is indeed a text file that can be interterpreted by a programmer that supports this format.
Pickit3 can import this file -- eg via MPLab. I still use a very old version in combination with PicKit3.
In MPLab: File -> Import -> select the Pickini hex file.
@Boadil
Glad you still like it 10 years later.
You could still improve it:
- adapt the main slicing level of the comparator with an an analog ground sample to introduce some sort of automatic GEB
- port it to a newer Microchip microcontroller
- preferably one with an internal clock speed higher than 32 MHz = more resolution to measure the pulse width
- port the code to the Microchip IDE instead of the MikroC environment I used at the time
- draw a new PCB with Kicad or some other up to date tool
- possibly introduce 2 different slicing levels for the comparator to get some idea of the slope and possibly some sort of rudimentary discrimination based on conductivity
I tried porting the Pickini4 code to an Arduino Nano once, but it lacked all sorts of nice features that were present in the 16F1824: speed, lack of comparator hysteresis, ADC resolution and speed, ...
Feel free to give this project a new life - or temporal sampling in general.
Best regards from Belgium,
- Bernard
