Delta Pulse
  • Hi brabra
    try:
    jap
    best time
    j.
    • After reprogramming the PIC ,discrimination does not account
      • U must set up your discriminator. The instructions are on Youtube. :-)
        • I know how to calibrate, but after reprogramming no can be calibrated
          • Originally posted by brabra View Post
            Oh-Oh?!!?!
            The reprogramming method was correct? How programmer do U use?
            I will use an Pickit2 clone and this work fine...
            • I use winpic800 software and hardware EXTRA-PIC,but i do not know how to set fuses bit
              • HI ALL
                is that I can use a pc charger to charge directly 12V lead acid battery?
                thank you best time
                P.
                • Hi pigeon
                  -For charging use an ac adaptor 12V-1A ,,,pc PS not use for charge!
                  best time
                  j.
                  • Hi brabra
                    -U hardware EXTRA-PIC it from the family of jdm programmer It does not succeed in family programming pic18fxxx ,Last attempt with PICPgm program if it fails , use Pickit2,or clon It successful.
                    best time
                    j.
                    • Hello Paloma
                      To charge a battery, you need a higher voltage than the nominal voltage of the battery.
                      For lead acid batteries of 12 volts, you need a charger that delivers 16 volts or more.
                      Then, an electronic circuit or a series resistance, regulating the charging current, usually 10% of the battery capacity.
                      A lead acid battery of 12 volts, can reach 13.6 to 13.8V when fully loaded.
                      Power PC, delivered 12,5 volts, thus not useful for this application.
                      José
                      • Originally posted by pigeon View Post
                        HI ALL
                        thank you best time
                        P.
                        Here's a good charger for 12V lead acid battery http://talkingelectronics.com/projec...er-12vSLA.html
                        • Originally posted by jap View Post
                          Hi brabra
                          best time
                          j.
                          Hi Jap
                          I programmed with EXTRA-PIC
                          • Originally posted by maikl View Post
                            hi
                            have a pcb please?
                            thank you
                            best time
                            P.
                            • PCB for this Click image for larger version
                              • I look the scematic of EXTRA_PIC. I was made this and use with an original PC serial port. With USB-Seriel adapter don't work!!!!! (this adapter not take an +5 and +12,5 volt)
