Delta Pulse
  • Originally posted by Alexis View Post
    Hello Manu ,
    For the coil :
    Diameter= 28 cm (11inch the best compromise rapport)
    - 19 TURNS Wire caliber= 25 Awg (0.45mm)
    Resistance = 2 Ohms ; Inductance only the coil =335 uH measured .
    A good Dynamic searchcoil.
    Have a good construction , Alexis.
    hi ineed detail for 15 inch coil plz.thank u
    • Originally posted by Jose View Post
      Hello everyone
      Delta Pulse works very well, can detect a soda can of 333 ml. At more than 1.40 mtrs. With coil 1X1 m. in the air.
      Sorry do not speak English.
      Hi Jose
      what is the specification of your coil ?
      what kind of wire you are used ?
      Thanks.
      Iman Boroumand.
      • Originally posted by Belief View Post
        Hi Jose
        Thanks.
        Iman Boroumand.
        Hello Belief
        I use flat cable 18 drivers that I provided elevator maintenance technicians, the diameter is 1 mm. approximately, the total resistance is about 2 ohm.
        I use MD damping resistance of 680 ohm, in the 1x1 meter coil added two parallel 2.2 K ohm (1.1 k ohm). The operation is stable.
        The scheme without modification as shown in previous posts.
        Sorry I do not speak English.
        • hi all..erm...tell me please your test...
          tell me please how to locate a football size target of bronze at 75cm up to 200cm..thk
            Hello Belief
            HI Jose
            Would you please send me your 1*1 coil's picture ?
            Thanks.
            Iman boroumand.
              HI Jose
              Thanks.
              Iman boroumand.
              Yes, I prepare the photos. A little time please.
              Best regards.
              • 400 Hz timings
                Maybe I am wrong but I've not been able to find this information on this 3D.
                Anybody, kindly, could post here timings for a DP working (tested) at 400 Hz? Thank you in advance.
                  HI Jose
                  Thanks.
                  Iman boroumand.
                  Coil Picture
                  • Hello Jose
                    140 cm for a coke .I did dot hear such distance. This forum begining a question about 45 cm for same coke.
                    Could you give a test video ? if it is so what is different on your Delta Pulse?
                    Best Wishes
                    Erol
                    • Originally posted by erolunall View Post
                      Hello Jose
                      Best Wishes
                      Erol
                      Dear Erolunall
                      I will try to prepare a video for next week.
                      The soda cans as are preserved, are easy to spot as iron, remember that these are ideal conditions and with maximum profit at the controls of MD and optimal adjustment of delay time.
                      Do not make major changes in the circuit, use lf357 (LF356 noisy).
                      TX power potentiometer 20 K, I use 10 K for IRF840 not overheat the 60% (approximately 120 microseconds).
                      Delay time from 20 to 30 microseconds, reducing training 1.5 na 1 n if necessary, otherwise as indicated in the scheme.
                      Good PCBs for minimum phase noise preamps (lf357)
                      Best regards
                      • HI Jose
                        Thanks for information
                        Best regards.
                        Iman boroumand.
                          Hello Jose
                          Best Wishes
                          Erol
                          Prueba Delta Pulse
                          Saludos Cordiales.
                            Hello Jose
                            Erol
                            Hi Erol, maybe you think 45cm for coin not for coke?
                            • hi can someone make a simple side pcb br!
                              • Hi Jose
                                I used it
