Thanks Ivconic.
Pictures give me more clear idea on how to do coils. Mines, have a 90 degrees bent on both sides on the coil. Has i see, you give around 45 degrees bent on both edges and some distance that for me seems to be 2 or 3 centimeters.
I ll be waiting for the next coples of pictures, to see how did you wharp the aluminium foil around the coil. Also how much preassure did you gave to the coil when you place the cord ( normal preassure or very tight).
My last coil is 220 cms, but detection for a vertical screew with a head not bigger than 3 mm of diameter by 7 mm long, is detected at 10 cms.
12 mm coin at only16 cms.
Best regards
Nelson
Best regards
Nelson
Originally posted by ivconic
