Originally posted by nelson
LM308 have nothing to do with what you experienced. It's the same with 308 or e.g. TL081 about this thing.
ApBerg and Quiaozhi gave you a good informations about what happens... look at silver response... I've made this test and it's reliable you must detect large silver coins and reject a ferrite stick or ring at say 5cm from coil. If not you'll have troubles on the real ground. I suggest you tune it for a medium soil where you know there is small mineralization due to iron oxides... but not too high cause otherwise you'll actually overbalance it.
You have to reach a point where raising or lowering the coil (fast) from soil would not give any false signal in a point you have tested there isn't any metal buried. You can use another detector first to be sure there isn't metal and then tune geb trimpot of TGS.
It's not easy at first attempt but you must repeat some times to be sure of your setting.
Then another thing... TGS have GEB pot on PCB so it's not like bandidoII that has an external fine GEB pot for all kind of terrains... so you have to use a panel-pot if you plan to use TGS in too different soils with e.g. heavy mineralization etc cause otherwise you'll be surprised by too many false signals... but I noticed that GEB work good in a wide interval of conditions and just extreme need adjusting... but I'll wonder if these fixed-settings are good e.g. for australian soils!
Nelson BTW what about weight of your TGS assembly , with coil and everything ?
Kind regards,
Max
