Originally posted by Geo
It will be deep! And i mean very deep! But as Max noted;y you should take special measures dealing with Faraday cage there..Must make hi-quality f.c....Personally i'' avoid Al foil in larger coils. I'll try some conductive material to obrain like graphite or simillar..There is certain skin effect occured when Al foil is used.Huge drawback! So, Al foil is suitable only for smaller diamm.coils...Another thing; less space between wires and foil - better. I am not usin any more scotch tape in between. When coil is wounded, next thing is to wind Al foil over it without anything in between.
20cm OO...good to try! If 0.25mm is used than you should start with 90 turns and measuring inductance try to adjust number of turns to achieve 6mH for TX ans 6.5mH for Rx...If 0.3mm is used than start with 120 turns...Do not pay to much of attention on resistances...If they are in range 17-25ohms than it will do the job. But do pay attention on inductances!
Bets regards!
