Originally posted by Math
TESORO GOLDEN SABRE
That is interesting point about parallel 10k pot on original schematic. I tend to agree.Originally posted by Pompey View PostWhen disrimination pot is replaced with 10k sinus on pin1 improves.Sinus on pin1 depends from Tx sinusoide.I tried this.When you put 10k disc pot Tx signal goes weaker and it`s crack at the top disapears -sinus on pin (LF353) improves too.I think that disc. pot must be 10k -in TGS there are 100k and 10k paralel,so 10k is correct I think.
However, the funny thing is that Molzar's original Tesoro TGS still had somewhat ugly waveform at LF353 pin 1 also, even with all the circuitry. That was surprising. http://www.geotech1.com/forums/showp...postcount=3896 (see pdf files).
But I agree 10k pot seems like it would be more consistent with original circuit. And your tests say it improves the signal so -- good observation!
I devised another circuit to get rid of the "oscillations", but I don't think it is worth trying if your oscillations are not too bad.
-SB
[quote=simonbaker;106338]That is interesting point about parallel 10k pot on original schematic. I tend to agree.
Hi Simon,
If you are referring to Image 3 (LF353 pin 1) in the pdf, the picture (left) is Max's handmade (which has distortion) the graph (right) next to it is the original machine / coil (no distortion)
So the original has no distorition.
Molzar
[quote=Molzar;106340]Thanks Molzar, I completely misunderstood your presentation. Now I understand; photos on left are Max's handbuilt, graphs on right are your original TGS.Originally posted by simonbaker View PostThat is interesting point about parallel 10k pot on original schematic. I tend to agree.
Hi Simon,
Molzar
So no distortion of discrim signal at LF353 pin 1. Makes sense now. Oscillations are because our handbuilts use larger oscillation voltage (because no feedback JFet), and it causes overdriving of LF353, which makes oscillations. Original TGS has smaller TX voltage (10 v pp).
Apparently 10k pot instead of 100k pot helps some in our circuit also, good to know.
-SB
The same for me. I thought that the images to take as good were the ones on the left!
Just now I realize we had the orignal TGS scope pictures sampled on a standard Tesoro setup (Tesoro coil and circuit). Very good.
But if these are the waveforms which we I can consider as reference, I can't understand why the pictures F1 and F2 show as phase difference of -20 and -30 where I expected to be +20.
[quote=Molzar;106340]Originally posted by simonbaker View PostThat is interesting point about parallel 10k pot on original schematic. I tend to agree.
Hi Simon,
Molzar
Same for me ....
Does anybody know if Max's machine did work with these scoop tracings ?
Dennis the Mennis
[quote=Dennis the Mennis;106483]I believe Max's machine worked fine. Apparently the oscillations in the discrim signal do not matter that much (surprise). However, if they are extreme, you will probably have trouble with the discrim control. In theory, those oscillations also lose a little gain from the detector. But very good TGSL machines are made even with some oscillations as far as I can tell.Originally posted by Molzar View Post
Same for me ....
Dennis the Mennis
The difference in null phase is curious also. However, as mentioned elsewhere, I feel the null phase is not as critical as others think, so long as the detector (Jfet) output bias does not go too negative and forward bias the JFet. Also, the original TGS may not perform as well as the home-builts, so maybe Max, Ivconic, and others have actually improved the design.
-SB
Are you using DD or concentic coils?
I think you have to take into account that the original 8" coil for TGS is concentric design, not DD. I think this is why (maybe?) shift is in other direction.
Other characteristic (Ampliture near metal or iron, direction of movement (left or right) of Rx signal when near metals.) are also reversed comparing concentric to DD.
Also not sure what coils Max was using during his test, DD I presumed, but I know he also had a Spider coil (concentric).
Also has been my experience that more Tx voltage (amplitude) creates more distortion, probably for the reasons stated in previuos posts.
Molzar
If you are refering to me :Originally posted by Molzar View PostAre you using DD or concentic coils?
Molzar
I'm using a DD , at least I'm trying to make it work with a DD coil , I don't know what Stefano is using if you were refering to him ( I thought he had a 8' Laser coil but I don't know what type it is )
Dennis the Mennis
Molzar
That is interesting observation. And i think you could be on right track.
Maybe i am wrong, but i think Qiaozhi already posted somewhere something about differences between DD and CC coil setups (reffering phase shifts etc..)
