IDX-PRO+VDI
  • hello, here are 2 videos showing how to idx. All metals in the first and the mode discrimination seoncde set to eliminate small nails and aluminum foil. If someone could help me pinpoint mode I threshold sound continuously when I approach a currency threshold disappears so I can pinpoint the run but as soon as I remove the threshold sound currency returns . the rest of the detector is operated. The THRESHOLD does not seem to be really on the operation.
    http://www.youtube.com/watch?feature...;v=aXo3hC4Dz18
    http://www.youtube.com/watch?feature...&v=cqSs4ldH2YI
    • Originally posted by ashefr10 View Post
      hello, for stability if you toujour the same problem, read the post 1252 edouardo R25 therefore advised to remove your resistance adjusted and put a 4k7 resistor between terminals 6 and 7 of the LM393 (IC4)
      The same thing was happening my, and remove the r25 resistance and places a resistance of 4k7 between the terminals 6 and 7 of the LM393 (IC4) And a nice sound has now
      • ok , pinpoint work? On my map I pinpoint mode continuous beep and when I approach a currency near the coil sound aténue and returns.
        • I do elips. TX 36 coils, 0,6 mf. RX 270 coils, 40 nf. Normally or not?
            I have the same problem pimpoit it sounds when withdraws the currency,
            And THRESHOLD is like a volume does not manage to remove
            Touching cables, potemsimetros pita idx me does not work very well resistance 4k7 does not convince me 4k7 only it does tone THRESHOLD work
            • THRESHOLD looks like a volume
              Problem pimpoit pita when withdraws the currency, and the THRESHOLD looks like a volume touches cables and sounds of potemsimetros, idx does not work very well.Help Help
              • pimpoit pita when withdraws the currency
                Idx pro was working correctly it is possible that screw vr3 on having touched it is desplasado phase?
                • hello , problem in mode PP , I made a video trying to show the problem.
                  http://www.youtube.com/watch?v=z2LeJUw1dzc
                  • How about you first set the offset properly?
                    • I found my fault, I reversed two resistors R34 and R35, 22k and 220k, I also put a bad value for the capacity c29 10 uF instead of 100 uF. thank you for your help. thanks
                      • solved potencimetro geb defective,Separated sensibility of ensendido
                        • tones does not work
                          Electronic shop me vendio tc4024bp serves for tones pedi cd4024 ,Help
                          • hello , mode pp work ! Hi, I noticed that the ferrous Mode pinpoint sounds not really. When I approach a ferrous and does not sound as soon as I remove the ferreur against sound by sound. you have this problem? for everything other metals such as bronze or other not no problem
                            • hello, I put at disposal of the idx 2 videos, the first fashion discrimination and pinpoint the second mode.
                              http://www.youtube.com/watch?feature...&v=6X2bbkKphk8
                              http://www.youtube.com/watch?feature...&v=oKu2QW24tOg
                              • 2k2 in vr3
                                I have put 2k2 in vr3 and one it sees the improvement and pinpoit that This sees beyond, Without the balance sheet of ferrita since I do not have tendre that to search, to coil 8 " concentric 30cm
