hello, here are 2 videos showing how to idx. All metals in the first and the mode discrimination seoncde set to eliminate small nails and aluminum foil. If someone could help me pinpoint mode I threshold sound continuously when I approach a currency threshold disappears so I can pinpoint the run but as soon as I remove the threshold sound currency returns . the rest of the detector is operated. The THRESHOLD does not seem to be really on the operation.
IDX-PRO+VDI
Originally posted by ashefr10 View Posthello, for stability if you toujour the same problem, read the post 1252 edouardo R25 therefore advised to remove your resistance adjusted and put a 4k7 resistor between terminals 6 and 7 of the LM393 (IC4)
The same thing was happening my, and remove the r25 resistance and places a resistance of 4k7 between the terminals 6 and 7 of the LM393 (IC4) And a nice sound has now
ok , pinpoint work? On my map I pinpoint mode continuous beep and when I approach a currency near the coil sound aténue and returns.
Originally posted by onuba View PostThe same thing was happening my, and remove the r25 resistance and places a resistance of 4k7 between the terminals 6 and 7 of the LM393 (IC4) And a nice sound has now
I have the same problem pimpoit it sounds when withdraws the currency,Originally posted by ashefr10 View Postok , pinpoint work? On my map I pinpoint mode continuous beep and when I approach a currency near the coil sound aténue and returns.
And THRESHOLD is like a volume does not manage to remove
Touching cables, potemsimetros pita idx me does not work very well resistance 4k7 does not convince me 4k7 only it does tone THRESHOLD work
hello , problem in mode PP , I made a video trying to show the problem.
hello , mode pp work ! Hi, I noticed that the ferrous Mode pinpoint sounds not really. When I approach a ferrous and does not sound as soon as I remove the ferreur against sound by sound. you have this problem? for everything other metals such as bronze or other not no problem
