Originally posted by golfnut
Please don`t call me a sir, I`m Rafal or reiv as You want. With this coil I have no problem at wett gras, high gras, bush, etc even 2 tone works ok on weet grass. I make my shield from mixing pure graphite with varnish, like satdaveuk wrote, with 1.5k per cm resis, and both covers are shielded. On top of that cabel i made by my self too.
, for example small 15mm diameter coin burried in ground is clearly see at 28cm..
wchich is for me awesome result, discrimination is sharp like a razor
. I get weight about 350g.
-but we all learns by mistakes). I never use graphite spray, some time my fried used it and he had problems with grass and his coil gives signal even to clear ground, when he changed shield it stops. Graphit mix is problematic to make, but it works well and it`s veery cheap
