By slowing the swing right down and sneaking up to a 6" rusty bolt that overloads the MD I can easy see 2 pound coin 2" away with a nice clean tone in disc mode.
"Sounds good"
For the nails, Im struggling a bit now, maybe your Rx coil tune frequency could be quite close to your Tx and giving a big phase pull with ferrous?
If yours air tests really well it may be the case - If you suspect the Tx and Rx are almost co tuned try a 1nF in parallel with the existing cap (Assuming your Rx tank is below Tx to start with) to pull it down a bit this may quieten it a bit?
That ground sounds as though its has many variables in it - grass, soil, then stones may be a bridge too far. Uniform flat clean earth is the holy grail here. short dry grass is ok, wet grass and thick clay are horrible.
You will find wet grass a pain as the wet grass has a phase and the soil has a phase and you can only get rid of one.
In your case you would have 3 return signal phases, the grass, the soil, the stone.. plus the rusty nail
I would say the best time for using our kit has nearly passed for this year. A lot of the laser/tesoros dont do well on wet dewy lush meadow grass.
I think even the ML Exploder doesnt like water in behind the coil cover.
S
"Sounds good"
S
