Parts question: which resistors are 1% metal? I thought %1 resistors were only necessary in the rx tx signal path? What capacitors should be poly? If I use a lm317t instead of the lm2930-8 do i risk frying components? Thanks
IDX-PRO+VDI
As far as I know in the original Whites IDX only R47 and R48 were a matched pair.Originally posted by wlewis View PostParts question: which resistors are 1% metal? I thought %1 resistors were only necessary in the rx tx signal path? What capacitors should be poly? If I use a lm317t instead of the lm2930-8 do i risk frying components? Thanks
Someone with more design ability than me would be able to say if any others are worth going to 1%
I used Poly(probably overkill)for everything except for the Aluminum Electrolytic ones near the PSU marked with a + on the schematics. C25,C27 and C29 Don't blame me if I missed one out my detector is all bolted up at the moment.Originally posted by wlewis View PostParts question: which resistors are 1% metal? I thought %1 resistors were only necessary in the rx tx signal path? What capacitors should be poly? If I use a lm317t instead of the lm2930-8 do i risk frying components? Thanks
Watch the size if you are using the silverdog board and sockets as two were very tight againt the socket.
I got all the parts today save for a few resistors.. Why did your detector bolt up? I'm not using the silverdog.. I'm going to have to build it out. Separately, What foil did you use to cover the coils? Did you use a conductive spray? Ref: I checked out Dan's coil. Also do you know if the silverdog pcb and schematic match?Originally posted by Koala View PostI used Poly(probably overkill)for everything except for the Aluminum Electrolytic ones near the PSU marked with a + on the schematics. C25,C27 and C29 Don't blame me if I missed one out my detector is all bolted up at the moment.
Detector is cased read for work. Very small case and short wires it's a pain to take apart.
Used a strip from a space blanket from a £1 shop. Conductive on one side so thin you can see through it. Did not check if PCB and schematics match just filled the values that was screen printed on the board. Did notice some of the resistors are different to the schematics on the first page of this thread.
HI my friendOriginally posted by Waka View PostCan someone explain the function of the pot threshod?. Is it necessary in this circuit?
thanks
olease read it :
golfnut
Guru
JandFirsly you have D3 crossed out in the schematic....
You will need this..
Most have a IN4148 in here... as per silk screen - You can use a 2v7 zener also - fit as per the schematic ( i.e. The zener would go one way around, the dide must go the other way around. ) I think we covered this before, twice
The Disc pot when set CW will reject Iron
The Disc pot when set CCW will NOT reject Iron
The Geb pot when set correctly will reject ferrite
I call the Sens pot the Threshold whish is very confusing I apologise.
The pot tha goes to the two comparators - this sets up a small positive DC level for which signals on BOTH Disc and GEB channels must exceed for a tone.
the pot at the top has its main use when in PP - if set too high the tone rings out continuously. So in PP require to back it off CCW so just no tone.
IN Disc mode leave this pot CW almost fully. This puts more positive DC bias on MPSA13 base - so closer to loud conduction. Works a bit like volume in Disc mode, It does reduce volume of HIT if set CCW
My friend Mr koala
first i change 47n to 22n+8.2n and can mor detect(i set once thershold for all) detect in 28cm
then 22n+8.2n+3.9n detect in 33cm
next 22n+12n+2.2n in 35or36 cm
it is good depth or no?
this coin for all above parts ( 26mm diameter)
but discrimination is not good and i think frist set Geb pot next do it, correct?(when i set Disc in CW fully can not find gold ring fine,not good sound when detecting that and iron things!!)l
hi dear gulfnutOriginally posted by golfnut View PostYou have a large DC offset at the preamp output of at least +3.5 volts.
That why the Rx signal looks clipped - its saturating on the pos rail..
This needs to straddle the 0V position
Make sure the rails are +4V and -4v WRT the copper around the cct board edge.
I dont know what you have done here to get this.
Put some good 2Mbyte images up in good focus with natural light and we will all try to help you
You could force a better DC offset condition like this...
[ATTACH]26873[/ATTACH]
S
how can i adjust to 0 point ,U1-pin6 ??
can you explain me a circuit ?or i use your example and add it to my borad, thanks
many thanks my guruOriginally posted by golfnut View Posttry a small trimmer - use the 26873 attachment.. Sounds like your making some progress - S
when i use this attachment i can imrprove very best , and i adjust it on 200mv.but in middle pot i add 22k and now is 22k+22k = 44k(i change it , true? )
look this pic befor adding attachment
and when i add the attachment in IDX , i use (22n+47n) and can detectat 28 to 30cm
, is it good depth for this coin ?
this is the pic , Yellow is ne5534-6 and Blue is Ref RX coil
Hello Mohandes,
There are very good depth of search for a homemade-detector!
If the coil about 30cm?
I also built the IDX.
I'm still waiting on wire (0.7 mm), so then i try to make a coil for my IDX.
Something else: I found years ago on the beach this coin.
I was surprised.
Here the beaches are found usually only Euros ....
What country is this coin? Unfortunately I can not read Arabic (only Latin and Ancient Greek
and a little bit english
Dixix
Hi Mohandes
I can see you have put a lot of effort into getting this to work. Well done.
You were on 35 or 36 cm with 22n+12n+2.2n I would go back to this
You can not get lower than 1 volt on pin 6 of U1 this is due to the nulling of the coil. You can try moving a small piece of ferrite between the coils. Hope you have not left the oscilloscope on 10X an easy mistake to make. If you can not null your coil then this will affect the detection distance.
Can not think of anything else that would help here unless there is some interference somewhere or metal nearby as my coil nulled fine. Anyone any ideas.
You are using using a LF347 as some alternatives have been know to cause problems.
A cheap set of earbuds (in ear headphones or earphones) are very good for testing PP mode it is much easier to pick up the change in threshold tone than a speaker.
Nothing jumps out at me as an error on your photographs but they are a little blurry
Hope this gets sorted soon
hiOriginally posted by Dixix View PostHello Mohandes,
[ATTACH]26946[/ATTACH]
I was surprised.
Dixix
this money for Iranain(says 2000Rial), and about depth are you sure it is good?
yes i use TGSL coil(DD) and 27.5Diameter.
oh realy i an read it ( your coin ) and write it(outer) :السابع من نیسان الذکر الخمسون لتاسیس حزب البعث العربی الاشتراکی
read this
http://www.baladee.net/?articles=topic&topic=4148
best wishes
