IDX-PRO+VDI
  • What is Coil L value or Dimater and turns
    One side of the Tx coil should be connected to Battery -ve terminal
    Dont make mistake of thinking PCB copper edge is battery -ve ( it sits 4volts above battery -ve terminal ) you cant use this copper edge for the tx return --- the tx coil return is the battery -Ve terminal
    • I do not know Inductance other than calculated in previous posts.
      But on TX, I used 35 turns of 0.7mm wire on a 27cm Diam Coil - for DD config, Cap=1uF, 30 ohms.
      And RX is 260 turns of 0.2mm wire also 27cm Diam, Cap=33nF, 120 ohms.
      • what is value of the two blue resistors standing up wired in series near Transistor ??
        • Originally posted by golfnut View Post
          They are a series of 2x of 20 or 21 ohm resistors. I did not have a 39 ohm.
          • Board BUS = +4V
            I replaced all the Transistors in case anything is burnt out :
            Q1 : BC327
            Q2 : BC547
            Q3 : BC547
            Q4 : MPSA13
            Tested with Multimeter to Battery GND :
            TX 1 = 0.0V
            TX 2 = +0.02V
            Q1 E = +8V
            Q1 B = +8V
            Q1 C = 0V
            Q2 C = +8V
            Q2 B = 0V
            Q2 E = +2V
            • Originally posted by ampirate View Post
              You can try with 100 Ohm R7 resistor to get oscillator working after that you can reduce to 51 Ohm.
              • I have a clear Sawtooth Oscillation of only 2V pp at about 300Hz across the TX coil - tested on Oscilliscope.
                  first you check without coil , see all +4v in all ICs with multimeter .if all thing right ( like value of res and caps and ......)
                  next you connect the coil . you should get in null less than 250mv ( pin6 ne5534 ) and.. ( see PDF file of make DD coil by Mr Dun make it )
                  and check part to part your PCB .
                  excuse for my English
                  • Originally posted by mohandes View Post
                    ... see PDF file of make DD coil by Mr Dun make it
                    I already have made Coils ...
                    Can you give me a Link or Page to this PDF ?
                    • looks like issue with Q2
                      In order to conduct and work - the base should be more positive than the emitter
                      by at least 0.7v
                      you got
                      Q2 C = +8V
                      Q2 B = 0V
                      Q2 E = +2V
                      base should be more positve than the emitter
                      check r values here,
                      also with battery disonnedted what is resistance from q2 base to batt negaitve terminal.
                      should be ~4k one way or very high the other way
                        i upload for you
                        you can make TGSL coil too , i upload it too.DD coil is more easiest than CC coil it is my experiment.
                        کامل‌ترین مرجع رژیم گیاهخواری؛ از مزایای گیاهخواری تا پاسخ به سوال چرا گیاهخوار شویم. همین حالا یاد بگیرید چگونه گیاهخوار شویم و یک سبک زندگی گیاهی سالم را آغاز کنید.
                          30 ohms does not sound right
                          • Sorry mistype,
                            TX = 1.4 ohms.
                            But on TX, I used 35 turns of 0.7mm wire on a 27cm Diam Coil - for DD config, Cap=1uF, 1.4 ohms.
                            • Measuring Resistance across Q2 Base to BAT GND in both directions gives me: 160K and Infinity.
                              All Resistors test as connected properly: 1M, 1.8K, 2.7K to Q2 and V+,V+,V- respectively.
                              I replaced the Transistors just in case.
                              Are these the correct Transistors ? :
                              Q1= BC327
                              Q2 = BC547B (in place of BC237)
                              • Multimeter readings to BAT GND :
                                V+ = 8V
                                V- = 0V
                                1M Resistor to Q2 Base = 8V and 0.14V
                                Transistors Q1 and Q2 test as connected, and are installed as in Layout Q1 face right and Q2 face left.
