Originally posted by g.s
Delta Pulse
HI
i need help in delta pulse
the mosfet heat quickly i used heat sink and i used 840 but again heat i used the old cicuit here in the picture i didnt add this diode and capictor around mosfet what i can do ?
my coil in 440 uh and 3 ohm uesd damping resistor 680 ohm
what i can do???????????????????????????????????????????????? ????????????????? please help me and if any body here make delta pulse i need his e-mail .....
DP is working good without the HV diode and the capacitor. Check PULSE WIDTH, check all connections to the coil - from MOS-FET to connector, connector itself. if you use TURKISH PCB layout check ALL WIRES POIN-TO-POINT OUTER CONNECTIONS.Originally posted by amel View Posti need help in delta pulse
THIS IS ALL TURKISH PCB LAYOUT.
THANKS KT
i will check my DP
this your attached picture i have guestion
and the second picture which i madeAttached Files
Hi everybody
I feel i'm near the solution
to repair my delta pulse, i wld like to give you some details :
* I have the right voltage value E (5.4 V) at all the check points expect pin 4 of LM555 i got (-2.04 V).
* continued sound from speaker with or whitout metal near coil.
* D5 (TL062) become quickly very hot.
for information i have just a multimiter
please some advices
Cordialy
Hi apocalypto
This is a mistake in making pcb like short- and result a damage or measuring voltage xxrong
First 1-I advise using a magnifying glass and examine the worked PCB on the tracks or short welding tin
2- out 2 ICS from the PCB project D5 (TL062)+lm555
3- measuring the dots task, such as 2pin oe c31 =10000uf +,- , as +12V,pin4,8 of lm555 And pin1 so on ---
-----After this-- You get =+12v and then put them{2 ICS} one after one with the measurement the same dots every time you put one in order to know if one of them is damaged.
best time
j.
best time
j.
thnk's Jap
1) I hv'nt now a magnifying glass
2) i removed the 2 ICs (TL062 and NE555) as you said, when i mesure voltage at pin 1, 4 and 8 of NE555 connexion i got (-6,8 at pin 1) and (5,4 at pins 4 /
3) I put the TL062 i got the same results of 2)
4) when I put NE555 i got (-2 V at pins 4 /
and (-6,8 V at pin 1)
cordialy
Hi apocalypto
you must use a magnifying glass!!!!!!!!
bad pcb
Mistake is clear
you must measurement +12v between c31 =10000uf+,- Equal to between pin4,8
And pin1 .
Mistakes are terminals to develop measurement Because there is an a virtual GND=REF
In the case of lm555 Only
The negative terminal of the black color in - (pin1).
The positive terminal of a red color in + (pin4,
if not Maybe the battery are damaged
Other like D5 (TL062)
The negative terminal of the black color in - (virtual GND=REF)
best time
j.
Hi freind JapOriginally posted by jap View PostHi apocalypto
bad pcb
Mistake is clear
And pin1 .
best time
j.
1) I got 12 V between +,- of C31 = 10000 uF
2) I got 10,33 V between pins (1,4) and (1,
of NE555
please JAP i used this pcb of bombaci (26.08.07 / Duzenlem : 02) is it a good PCB ? if i will made a new pcb what is the good ?
