Delta Pulse
  • Hi Geo. Yes i agree with you. My Tesoro Golden Sabre, doesn´t have any meter too, so i think that placing a meter (in my case) will be only for testing purposes.
    Thanks and regards
    Nelson
    Original Delta Pulse has an analog instrument (microameter). But for me ....DP don't need it. The sound is analog to meter indication so why to use it ?????
    My Opinion
    • for help
      Hi
      erolunall
      thank you very very much.
      • one side pcb for DeltaPulse has lcd
        Hi
        dear geo
        i saw to this site it has lcd
        if you want to see go to the site it.
        i want to build that deltapulse with lcd it but i think that anybody have not information
        about build it.
        pcb , component list ,and...
        by
        • 786 to aban
          Hi
          dear aban
          i heard that you are too profession .
          can you help me for build lcd for one side delta pulse.
          special hex file .
          i hope that you one know !!!
          if you know about it please help me.
          thank you.
          • small error
            Dear Friends
            I find a small error on delta pulse part replacement diagram that I send
            please careuful about this and correct. there must not connection beetwen 1n4148 and 27 k I attached picture.
            Somebody make error when copying from original.
            you can see original files at http://www.savefile.com/files/1018088
            and http://www.teknolojiekibi.com/yeni/index.php?topic=4.0
            Best Wishes
            Erol
            • i need your Frame.
              i need your Frame.
              Quote:
              Originally Posted by Geo
              Let's go again. Let's convert the square coil to circle.Perimeter of the 60x60 coil = 60x4=240cm
              perimeter=2*pi*r so r=perim/2*pi = 240/6.282 =38.2 cm.
              coil diameter=38.2*2=76.4 cm =30.07in
              Now from Gary's site (Inductance calculator, august 2003) we have:
              Coil inside diam=30.07in
              wire=20.5 AWG
              coil length= 0.3in
              L=0.722 mh
              It is near with my inductance meter and far from technick.net calculate for square coils.
              Now lets try with technick.net formula.
              N=22
              R=0.382 m
              a=0.0005m
              mr=0.99999
              L=1.56mH:confused:
              Smething is wrong. Lets try the other foormula as Leto wrote.
              (N * A)^2
              ------------- =L
              9A + 10B
              L= inductance in micro Henrys
              N= the number of turns
              PI= 3.141
              A= is the mean radius in inches
              B= the Length of the coil, in inches (not WIDTH !. Two turns at two turns per inch = 1 inch !)
              L=(22*15.04)^2/(9*15.04+10*0.3)=109481/138.36=791uH
              It is near with my inductance meter (780uH)
              OK. I will keep this size. So the other times i will believe everythink that shows the ind.meter.
              Thanks Leto
              Now for radioactive. Yes the dip meter is very good solution but this time i have not one. It is very easy to construct one but the main problem is the calibrate of indications
              My Regards
              Bye
              how you calculate B that get (i can not understand
              B= the Length of the coil, in inches (not WIDTH !. Two turns at two turns per inch = 1inch !)
              please by example show it to me .
              what happen that B gets =0.3
              i need your Frame.
              please with same 60*60.
              thanks alot dear geo
              • I DIULDED PALT PULSE ONE SIDE
                Hi all
                i builded it but i have problem.
                first i say that i dont have osiloscop and i cant see frequency .
                and while that i turn on the design coming sound like siren after 20" then silent and then siren and .....
                of course whithout coil.
                i want know that my design is right or wrong.
                by thank.
                i am sorry for bad english
                • hi
                  I faced same thing with you I solved it,but I dont remember how.
                  I said my friend wrong connection above post And he said his delta workinng
                  now. 1 euro about 35 cm.
                  But my delta worked 1 time but İt is not working after I changed coil.
                  I can not find problem.
                  But this design is working.
                  Always 1n4148 burning near IRF840.
                  I find 2 transistör burned
                  but not working now
                  Best Wishes
                  Erol
                  • hi
                    but not working now
                    Best Wishes
                    Erol
                    • hi
                      working dp
                      not mine
                      • Originally posted by erolunall View Post
                        Do you know about the coil at Video???
                        • Originally posted by 786 View Post
                          i need your Frame.
                          wire=20.5 AWG
                          coil length= 0.3in
                          L=0.722 mh
                          N=22
                          R=0.382 m
                          a=0.0005m
                          mr=0.99999
                          L=1.56mH:confused:
                          (N * A)^2
                          ------------- =L
                          9A + 10B
                          PI= 3.141
                          Thanks Leto
                          My Regards
                          Bye
                          i need your Frame.
                          Hi 786. With 26 turns of wire 0.5 ....0.6mm diameter you are OK (dimentions 60cm X 60cm).
                          Very good coil
                          • Hi Geo,
                            Did you change the R32 in your Sniffer? See the Sniffer forum...
                            Regards!
                            • Hello Geo
                              Coil is 40 cm 32 spin with adsl or computer network connection cable 8*4 spin
                              if you want to look how is maden look link it is showing with picture.
                              best wishes
                              Erol
                              • A Good picture with high resulition Delta pulse
                                İt will be usefull for builder of DP .
                                best wishes
                                Erol
