Delta Pulse
  • one?
    Hi all
    i have two ?
    1-can i change IN4001 WITH IN4007?
    2-which capacitor it is for delay time?
    thanks for reply
    • Originally posted by IRI2536 View Post
      Hi all
      i have two ?
      Yes
      1.5nf with 15Kohm are for first delay and 1.5nf with 68K are for second delay (sample)
      thanks for reply
      Hi
      • Hi,
        I have just started my DP, and it looks, that everything is working well
        Tommorow I'll buy missing LF357 and 555, but it can take me few days until I'll get AWG wire to make the coil.
        Photo of my DP, and photo of scope showing signals TR3 and TR5.
        • Hello pektro
          Irf reversed or is ti different
          looking reverse?
          Erol
          • Hi guys, Did any of you tryed to make coil for DP diameter 1M (100cm)?
            • Originally posted by strujas View Post
              17 turns with wire 1mm is OK
              Good luck
              • Originally posted by Pektro View Post
                Hi Pektro,
                You have soldered all potenciometers on the copper side of the PCB, so all controls will be reversed, did you do this on purpose?
                Fred.
                • Thanx Geo, I will make that soon!
                    Ok.
                    A friend tried it before 2 weeks with very good results.
                    • I haven't been enough precise, i am planing to construct square coil 1x1M, I supose that your friend had made round coil, square coil have bigger surface, and i supose that i need to wind less windings for square coil, 1 or 2 less, what you think?
                      Regards!
                      • Hi,
                        17 Turns is for 1m x 1m.
                        regards!
                        • Originally posted by 1843 View Post
                          regards!
                          Which thicknes of wire 1mm?
                          how much windings for 0.8mm?
                            Doesn't matter... 17 turns is ok.
                              Thanx
                              • i have ?
                                Hi all
                                i can not find the D(BAT46)
                                i want to change D(BAT 49) .CAN I CHANGE WITH (BAT43 OR BAT42)?
                                can you help me for this problem?
                                regards!
