Hi kt315. Here are the answers
1/ I use LF357 or TL081 in pre amp. NO, I M USING TL081 HAS IN MY PREVIUS VERSIONS
2/ I use 0,1% and more precise R23-R26. NO, HIGER
3/ my power supply wires go from batteries to switch 'Power On' then on C30-C31 and only after these go on the PCB. YES
4/ I use more than 2300 uA*hs charge value batteries. NO, ONLY 1200 uA
5/ all batteries are very good and were tested by Amperemeter. YES
6/ I use C7=1000 uF. NO
Nelson
Nelson
I dont have a signal to pin 12 of 4066, that goes from pin 10 of 4538.
excellent ..
but this is only 'at air' test, Tarsos. in ground you will get something another.
. Micron Electronics says that DP with a coil 1x1m can detect on air an object 1m x 1m at 3.5m
