Hi all,
what a lucky day!
Good news:
I have finaly found a logic level n-ch mosfet in my box. It's a IRLU 2905 (55 V, 42 A).
I have changed my TEM2 transmitter test board to operate with mosfets. Only minor changes are required.
Good news:
The IRLU 2905 is working fine with 2-cells battery voltage.
The power efficiency went up and the power consumption down.
I can test the transmitter for flyback voltlages up to 55 V now until I get other logic level high voltage mosfets.
Good news:
The transmitter noise can be improved by precisely setting the on/off timing of the transmitting transistor. At least 1 decade less noise. BTW, the noise is picked up by the TX-coil due to EMI noise sources. But precise switching timings do not add more noise.
Good news:
The Heater resistor R2 got a mate: The Magic Choke L1.
So the Heater won't heat anymore. They are working together and doing a very good job now.
Now fixed all parameters to get consistent the zero X-response.
We really need the series resistor R2 to have DC impedance to the transmitter (DC-blocking). And we need the high inductance choke L1 to have a high AC impedance at the operating frequency (AC-blocking). The critical energy balance works fine if the transmitter is decoupled well enough from the power source, to get big measureable effects.
We can also push more TX current through the TX coil.
Cheers,
what a lucky day!
Good news:
Good news:
Good news:
Good news:
Cheers,
