Originally posted by Dennis the Mennis
View Post
You are putting us to shame with your excellent use of laptop oscilloscope -- good stuff. I wish I had similar results from my mountain trips to compare. Maybe dfbowers can give you basement readings of noise.
Something does seem strange with GB noise -- it is normal for target signal to be much smaller in that channel, but I think noise should be similar to Disc channel.
Check the voltage on capacitor C12, is it above -.5 Volts?
Is the GB sync pulse pulling high enough (up to ground)?
A poor JFet TR5 is something to check.
Use your probe to check the noise at output of both LM358 U103a,b -- do you see the same comparison?
If you have a low frequency signal generator (5 Hz), you can put it on inputs of LM358 u103 and make sure the gain for GB is same as for DISC in the op amps (LM358 and LM308 ).
Thanks for answering many of the questions I've been wondering about, but now I have a whole new set of questions to figure out.
