Originally posted by eduardo1979
IDX-PRO+VDI
You have to remove the R25 (47 ohms). It resistor remove without putting anything in its place. Simply remove. Add 4k7 resistor between pins 6 and 7 of U4 (LM393).Originally posted by ashefr10 View PostI have to remove the 47 ohm resistor R25 to a wire in place and put a 4k7 between terminals 6 and 7 of the LM393?
thank you, they are not any pros as you, I am beginner I ask for advice. but good serious step.Originally posted by eduardo1979 View PostI think I lost patience. I think things are pretty clear. In the messages that I posted yesterday, I think everything is clear. I do not like to repeat the same things 100 times. I will not go over that. Regards.
Edurado could you just replay for my question in #1249
After this Yours update:
C23 - 3n9 -> 3n3
R24 - 1M -> 2M2
R25 - depends of U4 (my value about 800Ohm)
D2, D3 - out
VR3 - out, only R43 1k8 -> 2k2
I have worst masking, and my idx is a little unstable- is it normal or I have some sort of problem?
