Delta Pulse
    • labtec1, thank you for a reminder and the help! i was pressured by King Cobra PCB last time, it was a charge... but now i am free so will continue the work on DP
      • hi kt315
        please where's the pcb for this schematic?
        thank you
        best time
        p.
        • Hello KT315
          It's almost over, so if you have the time check and I'll finish it tonight kit
          I'm glad that there are people on GeotecClick image for larger version
Name:	delta pulse-1-1.jpg
            • Comment
              • still not finished PCB but there is still little to zavrÅ¡i.ko ia a Greco tell the correct time to
                question:
                DD2 goes where pin 7, 8
                DD1 pin 7, 9
                Which is better IRF740 IRF840 or
                C14, C15 reverse the poles sematić
                DA1 goes where pin 7
                DD1 pin 8 goes to the E-SE does not
                DD2 pin 8-E or not
                VD12 R36, R35 VD12 way or the error
                Thank you for your answers
                  • hi all
                    can you give me the exact adjustment of the delta pulse?
                    thank you and best time
                    p.
                    • Originally posted by jap View Post
                      Hi Nicolas
                      -Leave the speaker 8 OHM as it is because it is better.
                      -Be sure that your speaker is connected between the two pin 3-2 in J2(IN DP2).
                      -Be sure VOL=100 OHM=1K POT,R46=2.2 OHM
                      -To be safe change C27,C29.
                      best time
                      j.
                      Hi Jap
                      still the same problem I have tested almost all
                      let me know R46 = 2.2 Kohm or I misunderstood 2.2ohm
                      it is a confusion
                      1ohm to 1.8ohm resistors - standard EIA Decade Resistor color code examples for E12 resistors
                      Best Regards
                      NiKola
                      • Hi all
                        I finally finished the PCB design for the KT315.
                        question
                        free pins of the IC remains free to them or something goes
                        vd12-r36 and r35-vd13 wrong or vd12-r35 and r36-vd13?
                        DA3 and DA5 (TL062) to E-5 to pin or not?
                        C14 replaced iC15 place or not?
                        Does anyone can hang a picture C16, C18, C22, C25, and STTH1210D 7909 because it is in this crazy looks Serbia components purchased by first vendor show a picture and then he also seeks orderHere is the PCB, so if something does not wave a fixClick image for larger version
ID:	333929Click image for larger version
ID:	333930Click image for larger version
                        KT315 thanks to the scheme
                          • Originally posted by Nicolas View Post
                            Hi Jap
                            it is a confusion
                            Best Regards
                            NiKola
                            It is 2.2 ohms.
                            • last revision I play with.
                              yours
                                It is 2.2 ohms.
                                Hi Ivconic
                                Thank you for answering
