Need some help again.
This pic shows the output of LF357 at pin 6. I searched all across the board, but couldnt find an explanation of this signal. As far as I know, this shows the signal the coil recieves after turning off, right? The first ramp is the decay of the field, about 2µS after turn off it is at the minimum and then the circuit waits about 80µS till it takes a sample of the signal? I already changed the main frequency to about 900Hz and the delay time to be adjustable from 1,5µS to 65µS and the delay width to 1µS to 10µS, but I still get this long time before the ramp goes up again and i can take a sample. Is this long time in conjunction with the decay-speed and thereby the quality of the coil or is it set somewhere in the circuit. As I read on the internet, I need to take a sample after about 15µS to anything golden.
Btw, is it possible to take the sample on the "ramp" or before the "ramp" or just "ontop" of the ramp?
Sorry if my questions sound stupid, but I couldnt find relevant information on the net or on the board explaining this signal.
I use a 2,3Ohm 469µH 24cm coil.
