Hi
Hello,
I cant understand this.Until now I have used 2 together shielded cabels wired the way showed on your picture.But now when I read this I see many changes!So how to wire?TX and RX stat points to 2 cores,shields of cables and faradey cages all together.But then where to conec the ends of RX and TX?And on other hand how to wire to PCB?Cores to upper points for TX and RX?And leave ground point for RX empty.And conect shields of cables to TX ground point only?
If you draw a new clear picture I will be very greatefull.
Thanks.
p.s.I went prospecting yesterday with my TGS and havent found a single coin,but many rubbish colored ithems and a few large Irons afcours.But I have noticed that when I go near a high voltage line,my detector is not working!~!When I pick up my coil I can hear the electricity passing buy!!!A little bit scary.....The problem is that this is a good spot and I cant took advantage of it.
This time I had a feeling that my detector is not penetraiting!!!The land were just prepared for seeding and there were hugh level differances!May be because of this were the poor performance?
Originally posted by ivconic
View Post
Hello,
Thanks.
