Originally posted by Max
If you have made TGS already, than you dont need to make this one so fast.
Just change all capacitors on your pcb with WIMA's. Try to select best possible transistor couple for chopper stage and exclude from pcb Notch part.
And voila, you have this one.
But resistent problem with TGS and TGSL's i made is audio!
I simply do not like so short "beep" it produces when coin is detected over 35cm...!
Yes it is absolute true, it can cleary detect 2.5cm coin at almost 50cm in air.Not problem on this at all.But But audio is mum,weak and very short.Twice shorter than audio produced on coin ..let's say 10cm away from coil surface.
Generally audio is poor at this detector. So .... i want louder and longer audio. Ok...not much louder but longer sound.
That is only issue left to be solved on this. Once we do that TGS/TGSL would become best coinshooter ever - trust me.
Best regards!
