Do you mean this bump?
My scope is pretty accurate, just recalibrated it with test signal. I measured the frequency with my multimeter, but now I know it shows false numbers. When I test the frequency, the wavelenght in scope gets shorter, so it measured too high frequencies all the time
The TV inductor has around 11,6kHz at 7mH (27nF parasitic + real capacitance), TX around 11,3kHz (34nF parasitic + real capacitance) at 5,77mH and RX around 10,4kHz at 6,22mH (38nF parasitic + real capacitance) measured with scope. I guess the usb cable added even more parasitic capacitance
I guess I have to wind another coil <.<
I used some glue after I tied everything up with yarn and then i covered everything directly with alu tape.
.The TV inductor has around 11,6kHz at 7mH (27nF parasitic + real capacitance), TX around 11,3kHz (34nF parasitic + real capacitance) at 5,77mH and RX around 10,4kHz at 6,22mH (38nF parasitic + real capacitance) measured with scope. I guess the usb cable added even more parasitic capacitance
and it is another easy way to find out if the problem is in the coil or in the Tx part of your circuit.
) because they are dipoles flipping around...
and worked like some kind of capacitor without causing a short circuit. I will never use glue again.
porkluvr thanks for non-blury shematic and corrected values. These are also corrected on parts-placement (componentzijde) picture kurtie100 posted. No mistakes also on PCB - we could just wish for such complete projects like this one.
