Hi all,
this message is for friends here that need revised schematic and first PCB differences map....so it's easy find the hot-spots there...cause there aren't component label but just values on that.
So I repost again cause now thread is really long and somehow confusing.
Use revised schematic values... and you'll be fine.
Kind regards,
Max
Kind regards,
Max
. I have reversed the Rx leads without results. So then i checked the rx signal with Tx and i saw a phase difference. Did you checked the phase difference of Tx and Rx winds??? Is there any difference ???
so it is time to put it on the coil
